Author Topic: One wire lightning detector & I-button  (Read 10831 times)
Offline SoftWx
  • Moderator
    • SoftWx
Re: One wire lightning detector & I-button
« Reply #15 on: June 14, 2006, 09:50:55 PM »
You're in good company, because the virtual com port numbering confuses lots of people. It's probably the number one configuration problem. I need to come up with a good way to explain it, or hide  that complexity. The reason it works the way it works is because Windows allows only one program to connect to a numbered com port. N8VBvCOM creates pairs of virtual com ports, and connects the two ports with a virtual cable. VVP hooks up to one end of the cable (COM16 for instance) and the weather program hooks up to the other end (COM6 for instance). From VVP's point of view, it only needs to know the number of the end it hooks up to. It doesn't know or control what the number is that the weather program will use - that's configured in the N8VBvCOM driver.
What I probably should do, is parse the N8VBvCOM configuration file and display in the VVP Com setup screen what the port number is that the weather program should hook to. This would avoid some confusion, but there is nothing stopping someone from changing the N8VBvCOM configuration file without telling the driver to use the new information (in which case VVP would be suggesting the wrong port).
Steve
« Last Edit: June 14, 2006, 10:52:09 PM by tinplate »
Offline niko
  • syzygy
  • Global Moderator
  • Northern California, U.S.A.
« Reply #16 on: June 14, 2006, 10:14:17 PM »
That's a very helpful explanation  :)
Offline administrator
  • Administrator
  • Blackpool, UK
    • Weather-Watch.com
« Reply #17 on: June 15, 2006, 06:34:20 AM »
I see your problem with people changing the settings, but I think it's more confusing displaying VCOM17 when that's effectively an internal VVP/driver connection point rather than COM7 which is what most people will be dealing with in their end-user software.
Chris
Weather Forum Administrator
Offline bdtripps
  • Youngtown, AZ
    • Agua Fria Ranch Youngtown, AZ
« Reply #18 on: June 24, 2006, 02:32:04 PM »
Just to follow up, with VVP off and I set WD to com1 the lightning detector starts with no problems. But when I have VVP running & WD set com7 lightning detector cannot be found.
BTrip
B.Trip
DavisVP2/ Envoy Wireless, 2011 Mac Mini Server
Sierra 10.12.6, 2.3ghz Quad-Core Intel Core i7 16GB Ram
Arizona
