Author Topic: Suggestion for VirtualVP  (Read 3338 times)
Offline Zalmor
  • Erin, NY
    • Zalmors' corner of the Web
« on: May 30, 2006, 05:34:04 AM »
Great program by the way :D   No more shutting down WD or releasing the com port in WD just to startup WeatherLink.
Just registered my version here a few days ago. Could an option be added to settings drop down menu or even the setup program itself?  Like to start VirtualVP on a per windows profile basis?  For the moment I just created a link to VirtualVP in my profile 'startup' folder which seems to work out OK. Ahh, maybe the Windows scheduler might be better, takes awhile to load from the 'startup' folder.
One minor bug found, when the setup installed VirtualVP.  It created an 'VirtualVP website' link to the directory on my harddrive vice the actual website link on-line.
« Last Edit: May 30, 2006, 06:22:14 PM by Zalmor »
Michael A
Windows 10 Pro, Pentium Intel(R) Core(TM) i7-6700K 4.00GHz 24GB RAM, Quickcam Pro 4000, and APC
Offline SoftWx
  • Moderator
    • SoftWx
Re: Suggestion for VirtualVP
« Reply #1 on: May 30, 2006, 12:04:37 PM »
That's a good suggestion. I think I would add it as a settings option so you can turn the feature on and off as desired. I will look into the link issue and fix it for the next release.
Steve
