Author Topic: Max same day temp change?  (Read 3459 times)
Offline 2-Wheeler
  • 48 13 07.05 N, 122 41 11.84 W, Elevation: 95 ft
    • CoupevilleWeather
« on: April 11, 2006, 02:07:57 AM »
What is a reasonable limit for maximum same day temperature changes?
Today I saw 49 degrees (F) change from coldest to warmest!
Is this unusual?  My daytime temps seem to be consistant with other local readings, but my nights are colder, which has been my personal experience over the years with several different outdoor sensors.
-David Broberg   CWOP#: CW5670 / CoCoRaHS #CO-BO-218
Offline Leo
  • Wellington,NZ.
    • http://homepages.paradise.net.nz/lfduflou/Silverstreamweather.htm
Re: Max same day temp change?
« Reply #1 on: April 11, 2006, 05:21:48 AM »
Your Elevation could play a part. Are you at higher altitude than the other stations
you are comparing with ?
XP ProSP2 AMD XP2600+ 1GB ram IE7 Beta3 Cable Modem Z/A Pro
http://www.kiwiweather.co.nz/whitbyweather/
XP ProSP2 AMD XP3200+ 1GB ram IE7 Beta3  DSL Z/A Pro
Offline 2-Wheeler
    • CoupevilleWeather
« Reply #2 on: April 11, 2006, 01:20:09 PM »
Actually, I'm around 200-300 feet below the nearby stations, they are on hilltops, while I'm in a depression.
Offline Leo
  • Wellington,NZ.
« Reply #3 on: April 11, 2006, 01:25:58 PM »
Cold air rolls down slopes in the evening & pools in a hollow. Do you get more servere frosts ?
Offline 2-Wheeler
    • CoupevilleWeather
« Reply #4 on: April 12, 2006, 01:54:41 AM »
Yes, in fact that was a major factor in starting the weather station to develop the records to aid our gardening hobby.
Offline Leo
  • Wellington,NZ.
« Reply #5 on: April 12, 2006, 01:04:56 PM »
Sounds as though your large temp differential is correct then !
