Author Topic: Mebus TE923 / Honeywell TE923W / Irox USB pro  (Read 249200 times)
Offline sixpack
  • Juist, Germany
    • fly-roger
« on: April 10, 2006, 06:14:32 PM »
I can`t find my Mebus TE923 on the List. It is made by Hideki Electronis Ltd and also sold as Honeywell TE923 W. What Station settings are the correct selection for this usb Weatherstation?
« Last Edit: September 05, 2006, 03:03:43 AM by windy »
  • Davis VP2
  • New Zealand
    • Weather Display
Re: Mebus TE923 / Honeywell TE923W
« Reply #1 on: April 10, 2006, 07:29:03 PM »
is that the new one just out on the market?
Do you know any information about the data protocol?
does it show up as a USB to serial device in device manager (i.e does it need drivers to be loaded up?)
or is true USB data connection
Offline sixpack
  • Juist, Germany
    • fly-roger
« Reply #2 on: April 10, 2006, 08:16:15 PM »
Hi Windy,
i bought it new. Before i owned a ws2300, but this new one looks better. The windspeeds are correct now.That was the main reason to switch to another station.
The manual says nothing about the data protocol. I didn`t need any driver for the station. It came with an own software called WeatherView and you can download the software and manual at http://www.mebus-electronic.com/
By the way you don`t need 14 AA`s it came with a dc powersupplie for the mainstation. You need for the sensors 8 AA`s.
  • Davis VP2
  • New Zealand
    • Weather Display
« Reply #3 on: April 10, 2006, 08:31:55 PM »
does the software produce a log file that WD could read in?
Offline sixpack
  • Juist, Germany
    • fly-roger
« Reply #4 on: April 10, 2006, 08:55:57 PM »
The logfile is called records.txt it looks like this:
Year   Weekday   Month   Date   Hour   Minute   InTemp (degC)   InRH (%)   CH1Temp (degC)   CH1RH (%)   CH2Temp (degC)   CH2RH (%)   CH3Temp (degC)   CH3RH (%)   CH4Temp (degC)   CH4RH (%)   CH5Temp (degC)   CH5RH (%)   UV (UVI)   Baro (hpa)   Weather   Wchill (degC)   Wgust (MPH)   Wspeed (MPH)   W_Dir   RainCount
2006   1   4   10   18   59   21.5   38   8.8   59   999.0   999.0   999.0   999.0   999.0   999.0   999.0   999.0   999   1019.8   Little Cloudy   5.8   14.4   8.6   173   0
I don`t know how to open this file in wd
  • Davis VP2
  • New Zealand
    • Weather Display
« Reply #5 on: April 10, 2006, 09:10:36 PM »
so its text based?
looks promising :)
can you email it to me?
and then i will get wd to be able to read that in :)
Offline ukwoody
  • Kizzy - The boss!
  • Milford Haven, Pembrokeshire, Wales, UK
    • weather page
« Reply #6 on: April 10, 2006, 09:23:49 PM »
Sixpak. I highlited this product in another thread today, as a new product on the market.
Can you give us a few specs on it?
how often does it read the wind speed, how often to update readings etc.  Where are you and where did you get it from, also whats your first impressions?
regards
Woody
Semper in excreta sumus, solum profundum variat!
(We're always in the sh*t, it's just the depth that varies...!)
www.woodyspembs.org.uk
Offline aifan27
  • Tim
  • Pennsylvania
    • Newtown Weather
« Reply #7 on: April 10, 2006, 09:30:03 PM »
Woody,
It looks like he is located in Germany...
Quote
info@fly-roger.de
--Tim
Offline sixpack
  • Juist, Germany
    • fly-roger
« Reply #8 on: April 10, 2006, 09:39:28 PM »
before the mebus/honeywell i owned a ws2300 station.
The Mebus looks better than the LaCrosse WS2300. The Windsensor is much better ;-)
The sensors works fine, even the UV Sensor. The Main Unit stores 200 records and is linked via usb to the pc. Memorysaving interval is 1 hr without a pc. The intervals for the senors are:
tHERMO-hYGRO  47 sec
Rain                183 sec
Wind                 33 sec
UV                 300 sec
Inddor               10 sec
And yes it is true i am from Germany on a small island  called Juist in the northsea. The island is about 500 meters wide and 17 km long.
  • Davis VP2
  • New Zealand
    • Weather Display
« Reply #9 on: April 12, 2006, 01:48:27 AM »
i have added support for this station now,via the software that comes with it (you need to select that output file records.txt, after first ticking to use this station type (in the 2310 station type tab))
in a new 10.34L zip, download in a few hours from now  :wink:
Offline sixpack
  • Juist, Germany
    • fly-roger
« Reply #10 on: April 12, 2006, 06:40:10 AM »
I just download the new file, but where is the stationtyp hide? Where is the tab for the input file?
  • Davis VP2
  • New Zealand
    • Weather Display
« Reply #11 on: April 12, 2006, 06:55:53 AM »
in the la crosse setup, right down the bottom of that setup screen..
  • Davis VP2
  • New Zealand
    • Weather Display
« Reply #12 on: April 12, 2006, 11:01:27 PM »
http://www.tokaanuskihire.co.nz/WeatherD.zip
that zip version is not doing the data jumps anymore  :wink: #-o
( i hope, i will leave running, as I have to head out now)
update, yup, thats fixed that issue  :D
« Last Edit: April 13, 2006, 12:20:15 AM by windy »
Offline sixpack
  • Juist, Germany
    • fly-roger
« Reply #13 on: April 13, 2006, 08:29:12 AM »
It is like a wonder, the jumps are gone.
Thanks for that great work. One little think (i hope so) is not perfect working, but i hope you will fix it also.
Again thanks a lot for the fast help.
Roger from the otherside of the world
  • Davis VP2
  • New Zealand
    • Weather Display
« Reply #14 on: April 13, 2006, 08:55:26 AM »
yup, got your email about the wind direction and how its 1- 16
i have fixed that now.....and am uploading a new 10.34m version....
download that in a few hours from now :)
also, how much does the rain gauge measure by?
i have it at the moment being 1mm tips
