I just installed the kernel update to FC5, 2.6.16-1.2080_FC5, and when I run the GoWeather.sh, WeatherD crashes with the line “./GoWeather.sh: line 20: 2672 Segmentation fault ./WeatherD”
what weather station type?
i do know that someone reports that one of the kernal updates causes a bad memory leak with the com port comonent i have used
i have emailed the author of that so many times asking when will they fix that i am too scared to ask again
not much i can do when linux changes the kernal and breaks programs that were running just fine before
My weather station is a WS2310 connected to ttyS0. I had to go back to the original Kernel that came with the FC5 install ISO. The crach occured with the older version of weather display and the newest, 5.5E.
I’ve been experiencing similar symtems with Kubuntu breezy and kernel 2.6.12-10-386. There is a known memory leak in the nrComm lib that Brian uses for the Linux version. I’ve contacted them and they are aware of the problem and a fix is coming. I’m currently running v5.5f here, and it does work… just that I have a memory leak that requires a restart of WD every 5-6 hours. Btw, my weather station is a WM918 hooked up to com1. (0 in linux)
A few things to check about you’re error… first off, make sure you extract WeatherD-5.5c.tar.gz to your /home/username directory… otherwise you’ll experience the seg fault. Also, the upgrade v5.5f with a filename of WeatherDlinux.gz is NOT a gzip’ed file. (I’m sure you know this) It’s the binary of WeatherD which is in you’re /home/username/wdisplay directory. (Brian, maybe you should clarify this on the web site?)
