Hi everybody
Hope this is the right forum.
Does any of you weatherguys have any idea on how to prevent my winddirection from frezing, I only get one direction as seen on my webpage.
Hi everybody
Hi ,
I think North directon is default ( means you direction indications not working )
Was this working before and stopped recently ?
Could also be a problem with the WS ( indication mechanism eg … magnetic reed switch fault ) :?
or program bug
Check with Brian directly mailto:[email protected]
Hi Rocketman
The indicator is working OK.
It is only when temperature is below freezing, somehow water is getting in to the mecanism.
What I was wondering about is, is it posible to heat the housing in any way, or do I have to make a sleve to prevent water entering :?:
Hi, Conrad Electronics (Germany) sells heating pads for a low price…
It is a flexibel peace of plastic with metal strips on it.
Use a 12V adapter for power…
