I’m working on page you only have to put in the same folder as your clientraw files.It is in a pre-Alpha stadion but I sure will share it.
You can see it here: link removed
I am no programmer, just experimenting and putting things together I did find on the net
Joske
thanks to Brian humidity last 4 hours added
added some tags
correction of conversion of rain mm to inch (wrong function was used)
correction of warmest day and night of month and adding warmest and coldest day of year
layout tested for viewing in 800-600 1024-768 1280-1024
tested with FF (thank you administrator)
09/02/2006
change of layout(thanks again admin)
added a few things and included graphs (you need to do some work yourselves)
I’ve actually been thinking of turning the client raw on… and using AJAX to make the main page “live” but without using any third pary software (like Flash).
Unfortunately, it looks like June will be the earliest I’ll be able to play with it.
It’s much easier to read now, although I think there’s too much data presented on one page. It needs splitting across a number of pages and probably some graphics adding.
One minor point (which you probably know about)…the pressure values in the left hand column overlap the main body of page. That’s using FF1.51 if it makes a difference.
It’s looking good. I like the graphs. I’ve played with jpgraph before and it’s a very powerful package. I just wish I had enough free time to experiment with it some more!
