Here is an error I am getting. When I hit now to upload data it does nothing. The file itself updates itself like it should but will not upload to my host. Any ideas. The rest of my pages upload just fine it is just this file.
ERROR: Failed to set data for ‘D:\wdisplay\webfiles\wx3.html’ at time/date 9:41:53 PM 01/21/06
ERROR: Failed to set data for ‘D:\wdisplay\webfiles\wx3.html’ at time/date 9:41:58 PM 01/21/06
ERROR: Failed to set data for ‘D:\wdisplay\webfiles\wx3.html’ at time/date 9:43:24 PM 01/21/06
I removed wx3.html from my advanced internet settings. The reason I did that is because it would shut down ftpupd and would not download the rest of my files. Once removed the remaining files uploaded with no problem. There possibly might be a problem with at doc. Going out for a bit but will be back to look into it.
I tried that and it is still doing the same thing. I even tried putting a new wxlocal3 which of course put a new wx3 in the web folder. It is still not working at all. I think it is something from this end. When I press now to ftp it nothing happens ftpupd did not pop up in the system tray. Then I went and checked the program error log and there it was with the same problem. That is the only file that I am have problems with. It is driving me crazy. I have tried everything I can think of. If there is anything else please let me know.
You are correct. I deleted both files and recreated both and still get the same error. It has me sitting here scratching my head and drinking a Captain and coke. Cheers! I worked on it for at least 3 hours before I posted this. It is a weird problem I would have to admit. That is the only thing on my error log. I just checked it. I don’t know what else to do.
I renamed the file wxlocal10/wx10 and uploaded to host with no problem. There is something wrong with file #24. That is strange to say the least. I just have to update all my pages to indicate the change.
It worked just fine until yesterday. That is not the smallest file. It has been updating now for 14 hours after I renamed it to wx10. Just seems a bit strange that that was the only file that would not upload but it would update on my computer.
On the customise page, there is the box for other ftp servers. I have my info in the #1 server. Do I need that one in there. I am only uploading to one web server. I’m assuming yes. Is there an example how to setup the customise page. Just curious. Thanks!
that #1 ftp server setup is only needed if you want to upload to different ftp servers (not normaly used) (and you tick to upload to different ftp servers (and set which one, 1 to 3, for each file to upload to), otherwise the main internet ftp setttings are in the ftp/internet setup, connections setup
(which is copied to that #1 setup if that is not aleady set)
There is a FAQ on this, but it still reflects the old setup screen.
Brian, should I update it now - I know you wanted to hold off some until you got the “other servers” function working properly.
