New VP2 and Serial to USB
Dear friends.
Exactly what version of weatherlink do you have? If it’s a serial one then the wire from it connects directly to a com port and USB wouldn’t be involved at all. Using the com port to connect to the weatherlink is nothing to do with using a modem, this is only the way that the weather station communicates with the PC. Your PC’s connection with the internet isn’t affected by this, it will still be using dsl/cable/whatever connection you have.
[quote author=nikoshepherd
The drivers you are looking for are not with WeatherLink.
The drivers are for the USB to Serial adaptor and will be included with that hardware.
It’s a very confusing post, he says he has a serial, but then talks about the USB driver :?
Thanks… I owe you one. That was what I needed to know and you said it so gracefully.
