Author Topic: METAR x WINAPRS  (Read 6156 times)
Offline ZZ2MUS
METAR x WINAPRS
« on: December 04, 2005, 11:44:21 PM »
I`ve used WinAPRS in WIndowsMe for a long time without problems.
In the same pc, I installed Weather-Display 10.30w to plot in APRS a METAR archive acessed trough FTP from another site.
First problem : the APRS Data Send only works when I press Test, the upload scheduled for every 5 minutes doesn`t work.
Second problem : the FTP/Metar download only works when I press Test, the upload scheduled for every 5 minutes doesn`t work.
Third problem : the temperature and wind speed only appear on the display but don`t appear in the graphics and these don`t appear in WinAPRS, only wind brg and bar press appear.
My version is a demo , is this the cause of the problems ?
Obs.: The same problem happens with WindowsXP
Thanks a lot, Marco/ZZ2MUS  :roll:
« Last Edit: December 04, 2005, 11:45:52 PM by ZZ2MUS »
Offline JaxWeather
  • Bob
  • Global Moderator
  • VP 2 w/FARS - WML Station: WD00007
  • Jacksonville, Fl. USA
    • JaxWeather.net
Re: METAR x WINAPRS
« Reply #1 on: December 04, 2005, 11:48:49 PM »
Marco,
Do you have the Main Internet Switch turned "ON" under "Control Panel - FTP - Connections"
Offline heli1
Re: METAR x WINAPRS
« Reply #2 on: December 05, 2005, 01:00:33 PM »
We're having the same problem too. We're trying to email a METAR every 15min and 'it just don't work' (unless you invoke it yourself).  I suppose it must have worked once... :?
  • Davis VP2
  • New Zealand
    • Weather Display
Re: METAR x WINAPRS
« Reply #3 on: December 06, 2005, 03:52:16 AM »
yes, make sure the main internet switch is ON
and you have ticked, use ftpupd.exe in the connections setup, or at least have ticked,still use for all other
worse comes to worse, email me your settings (see in the FAQ for how to do that) and I will try here
Offline ZZ2MUS
Re: METAR x WINAPRS
« Reply #4 on: December 06, 2005, 10:23:46 PM »
Thanks Bob for helping  me with the first and second problems. They`re solved.
I need more info about the third problem. The package received in APRS and the archive WXNOW.TXT don`t contain the values showed in the display.
APRS PACKAGE= ZZ2MUS-11>APRS,TCPXX*,qAX,ZZ2MUS-11:@030034z2356.70S/04621.38W_0-0/000g012t032r000p000P000b10130h93.WD
WXNOW.TXT= _12052001c0-0s000g009t032r000p000P000b10130h90xOWWD
Thanks the any information about it.
  • Davis VP2
  • New Zealand
    • Weather Display
Re: METAR x WINAPRS
« Reply #5 on: December 06, 2005, 11:27:03 PM »
it looks like you using the wxnow.txt from the OWW program still
try changing the location of the wxnow.txt file to use to that one produced by WD in the winaprs program
