I’ve had several people say they like the original single page template as the home page, so my next custom template will be a modification of this template. It will incorporate the original single page template as the main page.
Hope you don’t mind, but I found a little bug I think.
On the “Daily Stats” page, under “hot days this month” & “cold days this month” the first two tags under those headings are not rendering properly.
I am so impressed! You sure put a lot of work into this - thanks so much for sharing!
Have some more editing to do, like on the “about us” page, etc, and a small CSS change to suit my taste…
OK - got it. I ended up having to open the page up in notepad to make the change.
For some reason NVU is doing this. I went into advanced properties, and tried a couple different settings without any luck.
Anyway, got it fixed.
Thanks!
Wow - all those tags sure makes WD do some crunching!
I just finished getting the 1 pager working, looks like this will be a project for tomorrow night.
One quick question is there a way on the forecast to get the NOAA weather icons to link?
http://www.allshouse.net/AllshouseWeather.html
greg, you need to set a lower theshold for the barometer and temperature , to avoid the barometer and dew point lines from going out of range
Tom, this is a great page. I tried the 1st one and got alot off feed back. It ran about 70/30 against the new page. I think they’ll like this one, it has the things they wanted from the other page.
I’ve downloaded it and TRIED to fill in the blanks site name,town, radar, ect. But it wont stick. Always goes back to default. Any advise?
The long answer is that you have several options not covered in the basic template. You could add a third party graphic with the icons like from Weatherforyou.com, you should use an
