Author Topic: Full site template no. 1  (Read 62796 times)
Offline carterlake
  • Tom Chaplin
  • Carter Lake, Iowa USA
    • Carter Lake, Iowa Weather
« on: November 10, 2005, 12:51:31 AM »
Example site:
http://www.carterlake.org/template1/
Template files (including readme.txt install):
http://members.cox.net/carterlakeweather/templatewebsite1.zip
I've had several people say they like the original single page template as the home page, so my next custom template will be a modification of this template. It will incorporate the original single page template as the main page.
« Last Edit: November 10, 2005, 01:22:20 AM by carterlake »
WD; Davis VP2 6153; Quickcam for Notebooks Pro; Boltek w/ Nexstorm; GRLevel3; Live NOAA radio
Offline daveq
  • Hollywood, MD
Re: Full site template no. 1
« Reply #1 on: November 10, 2005, 01:02:32 AM »
Wow, Tom.  They look great!
Can't wait to get it set-up.
--Dave
Just noticed it has the NOAA warnings!!  Pleasant suprise.
« Last Edit: November 10, 2005, 01:04:57 AM by daveq »
  • Davis VP2
  • New Zealand
    • Weather Display
« Reply #2 on: November 10, 2005, 01:08:29 AM »
there is an alignment problem in FF tom...  :wink: 8)
Offline carterlake
  • Tom Chaplin
« Reply #3 on: November 10, 2005, 01:11:25 AM »
Fixed!
« Last Edit: November 10, 2005, 01:22:41 AM by carterlake »
Offline snowman
  • C'Mon Snow
  • North Central Pa USA
    • sterlingrun.com
« Reply #4 on: November 10, 2005, 01:22:10 AM »
Drools with anticipation  :tongue:
~Stan~
Offline carterlake
  • Tom Chaplin
« Reply #5 on: November 10, 2005, 01:30:03 AM »
--Dave
Dave, you'll want to re-download it if you haven't already... minor problem with Firefox in the original.
Tom
Offline snowman
  • C'Mon Snow
    • sterlingrun.com
« Reply #6 on: November 10, 2005, 02:13:47 AM »
Tom,
Am I loosing my mind, or is wxlocal8 missing (links page)?
~Stan~
Offline carterlake
  • Tom Chaplin
« Reply #7 on: November 10, 2005, 02:20:32 AM »
Tom,
Nope... I'm losing my mind... I completely left it out of the zip file.
Fixed and reuploaded. (this is just not my day for custom templates)
Offline snowman
  • C'Mon Snow
    • sterlingrun.com
« Reply #8 on: November 10, 2005, 02:28:13 AM »
Well, maybe this will make your day a little better....
Here's my first quick attempt (without the links page working)  :D
I'll be editing it some more for sure, but it all works
http://www.sterlingrun.com/weather/wx10.html
I'll put the links page in now.....
~Stan~
Offline carterlake
  • Tom Chaplin
« Reply #9 on: November 10, 2005, 02:46:31 AM »
That does make it all worthwhile. Thanks!  8)
(I wonder if anyone will leave the "About This City" in there...)
Offline snowman
  • C'Mon Snow
    • sterlingrun.com
« Reply #10 on: November 10, 2005, 02:49:01 AM »
Ok - got the links page working.
Hope you don't mind, but I found a little bug I think.
On the "Daily Stats" page, under "hot days this month" & "cold days this month" the first two tags under those headings are not rendering properly.
I am so impressed! You sure put a lot of work into this - thanks so much for sharing!
Have some more editing to do, like on the "about us" page, etc, and a small CSS change to suit my taste.......
THANK YOU!    :D :D :D
~Stan~
Offline carterlake
  • Tom Chaplin
« Reply #11 on: November 10, 2005, 02:55:55 AM »
Nope... I doublechecked the template.... what are you editing the files with? It changed > into > and that broke the custom tags.
Offline snowman
  • C'Mon Snow
    • sterlingrun.com
« Reply #12 on: November 10, 2005, 02:58:04 AM »
I'm editing with NVU - I'll go back and check it out right now...
Probably a question for Brian, about the moon tags - they seem to show only in UTC - I can't find how to change to local time.
Be right back.....
~Stan~
Offline snowman
  • C'Mon Snow
    • sterlingrun.com
« Reply #13 on: November 10, 2005, 03:20:27 AM »
OK - got it. I ended up having to open the page up in notepad to make the change.
For some reason NVU is doing this. I went into advanced properties, and tried a couple different settings without any luck.
Anyway, got it fixed.
Thanks!
Wow - all those tags sure makes WD do some crunching!
« Last Edit: November 10, 2005, 03:22:47 AM by snowman »
~Stan~
Offline Gregal
  • Greg
  • PA / USA
    • Allshouse_Weather
« Reply #14 on: November 10, 2005, 03:51:37 AM »
Tom
They look great.  Thank you for a job well done.
I just finished getting the 1 pager working, looks like this will be a project for tomorrow night.
One quick question is there a way on the forecast to get the NOAA weather icons to link?
Greg
