I am having problems with the weather report e-mail. I have WD version 10.26s. It is uploading at the set times but I am not receiving anything when I check my e-mail. I have followed the WD operation manual “sending weather reports by Email”. I have a spam inspector program but have it disabled. Any suggestions to correct the problem?
Since you are getting uploads it sounds as though you do have the Main Internet switch turned on.
Do you have “Setup - Control Panel - FTP/Internet setup - Data file upload/email” enabled?
Check that you have “Weather Report Email - Main ON” in the FTP/Internet setup and the proper settings set for your SMTP mail server.
Then look under “View - Averages/extreme Noaa style reports - Noaa reports / email reports / web uploads / print reports” and make sure you have “Email the NOAA report” daily enabled
You should be able to test the Daily NOAA report then from the last screen above.
If you still don’t get the report you may want to try another email address and see if it gets there…
I am not sure if there is anywhere that WD logs email related problems…
Ok, I have double checked all of my settings from everyone’s suggestions but with negative results, although, I am not sure I really have things ticked that should be. I have tried another e-mail address but still get nothing. It might be helpful if someone could give me step by step instruction in each of the locations where it needs to be set up, as there seems to be several… #-o
i have this problem too ? all my setting are right becaue when you Do TEST i get th e-mails of reprots but soon as i leave it alone it dont sent nothing up ? so why dose the test work but not on it own 8O
will do but my parter going to have a check on our setting first just in cases something blocking it
later on NO its all working fine ? #-o here is a screenshot
