Weather-Watch.com
Weather and the Internet => Creating Weather Web Sites => Custom Templates and Scripts => Topic started by: mth on March 20, 2010, 02:01:38 AM
Title: Rain "Year to Date" and "Month to Date" Differential Script
Post by: mth on March 20, 2010, 02:01:38 AM
Murry Conarroe of Wildwood Weather (http://weather.wildwoodnaturist.com/ (http://weather.wildwoodnaturist.com/)) has graciously developed a nice script to calculate the "Year to Date" and "Month to Date" rainfall differential (departure from average) totals that utilizes the dailynoaareport files created by Weather Display.  The script will update these differential totals on a daily basis and utilize your entire historical data archive.
See my dashboard under the Rain section (note the MTD Differential and the YTD Differential) http://www.relayweather.com/
Additionally, I've added the differentials in my "Rain Trending" page at the bottom of the main table: http://www.relayweather.com/wxraintrending.php
To use the script, download the raintodate.php file (there are a couple of adjustable settings at the top) and add the following line to your dashboard file.
Code: [Select]
include_once('raintodate.php');   // for ytd/mtd rain calculations
It needs to be somewhere after the
"include_once($WXtags);   // for the bulk of our data"
line to ensure that the variables in the testtags.php file are available.
The two variables created by the raintodate.php file that you can use anywhere in the dashboard are $avg_ytd_rain and $avg_mtd_rain.
I know that this has been a desirable variable that many of us want!  Many thanks to Murry! :occasion5:
Title: Re: Rain "Year to Date" and "Month to Date" Differential Script
Post by: FrankP999 on March 20, 2010, 12:33:35 PM
mth
Can you please explain how to implement this? I am unclear what you mean by "add the following line to your dashboard file." What is the dashboard file?
Frank
Post by: BfdWx on March 20, 2010, 12:42:56 PM
Frank,
In your 'new weather pages" page (http://www.frankpinkston.com/weather/wxindex.php) that is your "dashboard". It would be the file named ajax-dashboard.php
Hope this helps!
Jack
Post by: mth on March 20, 2010, 04:18:33 PM
mth
Frank
Frank,
As Jack stated, you place this line of code into the file.  (preferrably at the top of the file but below the call for the WXtags or testtags)
This then allows you to have use of the two tags that the raintodate.php script creates.
Year to Date Rain Difference from Average: $avg_ytd_rain
Month to Date Rain Difference from Average: $avg_mtd_rain
Michael
Michael
Post by: ed2kayak on April 18, 2011, 09:49:44 PM
Just tried this script. Thanks
http://cvweather.org/wxraintrending.php
Not sure It working correctly for me
I believe that I have all the testtags added correctly.
For march I only have 0.01 in. We had 5.57 inches of rain March.
Post by: mth on April 18, 2011, 11:36:30 PM
Something is not right there....do you have the path set correctly for the dailynoaareport files?
I believe yours should be set like this:
$loc = "./"; // set to path of dailynoaareport files
For the averages column, the following tags are required:
$avrainjan
$avrainfeb
$avrainmar
$avrainapr
$avrainmay
$avrainjun
$avrainjul
$avrainaug
$avrainsep
$avrainoct
$avrainnov
$avraindec
These variables are taken directly for WD.
Post by: ed2kayak on April 18, 2011, 11:51:53 PM
Checking now, your climate report for March 2011 shows 4.20 in of rain, but your wxraintrending.php shows 0.00 for March 2011.?
Maybe I'm confused about how it works.
Yes my dailynoaareport is at $loc = "./"; // set to path of dailynoaareport files
Post by: mth on April 19, 2011, 12:38:21 AM
You're correct, something is wrong with my March tag ($avrainmarnow) in WD.  I just got the old script out (been a while) and these are the tags that are required.  Notice my March total is 0.00.  I need to look into that.
//Start Rain Trending
$avrainjan = '2.43';
$avrainfeb = '2.23';
$avrainmar = '2.75';
$avrainapr = '3.96';
$avrainmay = '3.28';
$avrainjun = '3.66';
$avrainjul = '4.12';
$avrainaug = '3.72';
$avrainsep = '4.73';
$avrainoct = '3.54';
$avrainnov = '2.45';
$avraindec = '3.64';
$avrainjannow = '1.95';
$avrainfebnow = '2.72';
$avrainmarnow = '0.00';
$avrainaprnow = '2.27';
$avrainmaynow = '3.06';
$avrainjunnow = '0.94';
$avrainjulnow = '5.53';
$avrainaugnow = '2.75';
$avrainsepnow = '7.24';
$avrainoctnow = '3.02';
$avrainnovnow = '2.00';
$avraindecnow = '1.77';
//End Rain Trending
Post by: mth on April 19, 2011, 01:52:00 AM
Ed,
I got my March rain total squared away, there was a bug in WD.
I see in your testtags file that you don't have the following set up:
$avrainjannow
$avrainfebnow
$avrainmarnow
etc.....
Post by: drobbins on April 19, 2011, 02:11:18 AM
It looks like the tags are in and working:http://www.cavecountryweather.com/index.php (http://www.cavecountryweather.com/index.php)
Couple of questions:
1. How to add the + and - symbols?
2. I am not quite sure where the value "YTD Differential:    16.66 in " came from and is it + or -  ?
Code: [Select]
<tr>
                <td class="data1">MTD Differential: </td>
                <td style="text-align: right;" class="data1">
                  <?php echo $avg_mtd_rain $uomRain?>
                </td>
Post by: ed2kayak on April 19, 2011, 02:49:21 PM
How did you correct March?. Testtags, not sure what happened. This time I deleted them in my webfiles folder, then they were overwritten w/the new ones.
ED
Post by: ed2kayak on April 19, 2011, 03:47:14 PM
I tried converting log files to data, nothing worked.
But view>rain chart>mth to correct fixed it for me.
Post by: mth on April 19, 2011, 11:21:58 PM
It looks like the tags are in and working:http://www.cavecountryweather.com/test.php (http://www.cavecountryweather.com/test.php)
Code: [Select]
<tr>
                </td>
Drobbins,
Its been a very long time since I added this....this is what I have in my ajax-dashboard for the MTD and YTD rain totals:
For the Month to Date (MTD):
Code: [Select]
<td class="data1">MTD Differential:</td>
  <?php $monthrndifference=$monthrn-$avg_mtd_rain;
  if ($monthrndifference >= 0)
     echo "+";
   else
     echo ""
          <?php $monthrndifference =  round($monthrndifference,3);
$monthrndifference =  number_format($monthrndifference2'.''');
  <?php echo "$monthrndifference$uomRain;?>
</td>
and for the Year to Date (YTD):
Code: [Select]
<td class="data1" nowrap="nowrap">YTD Differential:</td>
  <?php $yearrndifference=$yearrn-$avg_ytd_rain;
  if ($yearrndifference >= 0)
     echo "+";
   else
     echo ""
          <?php $yearrndifference =  round($yearrndifference,3);
$yearrndifference =  number_format($yearrndifference2'.''');
  <?php echo "$yearrndifference$uomRain?>
</td>
Currently, you're only displaying the average month to date rainfall.  You need to change your code.  Basically, based on all of your data since station inception, you've averaged 3.08" of rain from April 1 to April 19.  Then you compare this value to the current month rain to come up with a "+" or "-" value from normal.  Same applies for the year to date rain but starts from Jan 1.  I hope this makes sense.
Michael
Post by: drobbins on April 20, 2011, 12:59:07 AM
Yes it makes sense. Unfortunately I don't know how to write the code. I copied and pasted yours and it is working perfectly.
Much appreciated! :hello1:
