Author Topic: WD SHUTSDOWN AFTER UPGRADING FROM LA CROSSE TO DAVIS VP  (Read 5561 times)
Offline far_ken_beauty
  • Portland Bay Weather
  • Portland, Victoria, Australia
    • Portland's weather
« on: July 01, 2005, 05:18:47 AM »
I just upgraded me La Crosse WS2300 to a DAVIS VP. It is all setup and working how it should in WD with the USB logger however....I have had the Davis VP in operation for 3 days and on each of these days WD has shutdown for some reason. It has happened at 3 different times. There is nothing in the system event log or the WD log. I upgrade to the latest WD and still no good.
I noticed that my website was not updating so I jumped on the server (WIN2K3) and thats when I noticed that WD was not running. I had no problems with this for the La Crosse station.
Your help would be much appreciated.
Re: WD SHUTSDOWN AFTER UPGRADING FROM LA CROSSE TO DAVIS VP
« Reply #1 on: July 01, 2005, 05:36:00 AM »
is it doing it at a certain time each time?
any errors in the file programerrorlog.txt (where wd is installed)?
do you like the VP?
« Reply #2 on: July 01, 2005, 05:54:32 AM »
yes there is...as pasted below.
these errors date right back ...the resetting rain daily value and resetting wind/temp ones in bold.
However the tell tail is probably in the errors below that.
Resetting rain daily value , day: 3
Above error or program log occured at :0:00:00 03/04/05
Resetting wind/temperature daily value , day: 3
Above error or program log occured at :0:01:00 03/04/05
Resetting rain daily value , day: 29
Above error or program log occured at :0:00:00 29/06/05
Resetting wind/temperature daily value , day: 29
Above error or program log occured at :0:01:00 29/06/05
 at time/date 11:20:14 29/06/05
Above error or program log occured at :11:20:14 29/06/05
 at time/date 11:30:03 29/06/05
Above error or program log occured at :11:30:03 29/06/05
 at time/date 11:40:03 29/06/05
Above error or program log occured at :11:40:03 29/06/05
 at time/date 11:50:03 29/06/05
Above error or program log occured at :11:50:03 29/06/05
 at time/date 12:00:01 29/06/05
Above error or program log occured at :12:00:01 29/06/05
ERROR: Access violation at address 900004C2. Read of address 900004C2 at time/date 12:01:03 29/06/05
Above error or program log occured at :12:01:03 29/06/05
ERROR: Access violation at address 900004C2. Read of address 900004C2 at time/date 12:10:03 29/06/05
Above error or program log occured at :12:10:03 29/06/05
ERROR: Access violation at address 900004C2. Read of address 900004C2 at time/date 12:20:03 29/06/05
Above error or program log occured at :12:20:03 29/06/05
ERROR: Invalid pointer operation at time/date 12:22:00 29/06/05
Above error or program log occured at :12:22:00 29/06/05
ERROR: Access violation at address 7C8396D0 in module 'ntdll.dll'. Read of address 34312051 at time/date 12:23:01 29/06/05
Above error or program log occured at :12:23:01 29/06/05
ERROR: Access violation at address 7C8396D0 in module 'ntdll.dll'. Read of address 3A32304E at time/date 12:24:02 29/06/05
Above error or program log occured at :12:24:02 29/06/05
ERROR: Access violation at address 7C8396D0 in module 'ntdll.dll'. Read of address 3A32304E at time/date 12:25:02 29/06/05
Above error or program log occured at :12:25:02 29/06/05
ERROR: Access violation at address 7C8396D0 in module 'ntdll.dll'. Read of address 3A32304E at time/date 12:26:02 29/06/05
Above error or program log occured at :12:26:02 29/06/05
ERROR: Access violation at address 0041E84A in module 'WeatherD.exe'. Read of address 00000015 at time/date 12:27:00 29/06/05
Above error or program log occured at :12:27:00 29/06/05
ERROR: Access violation at address 7C8396D0 in module 'ntdll.dll'. Read of address 00000014 at time/date 12:28:00 29/06/05
Above error or program log occured at :12:28:00 29/06/05
ERROR: Access violation at address 00403234 in module 'WeatherD.exe'. Read of address FFFFFFFF at time/date 12:29:00 29/06/05
Above error or program log occured at :12:29:00 29/06/05
ERROR: Access violation at address 7C8396D0 in module 'ntdll.dll'. Read of address 20253139 at time/date 12:30:05 29/06/05
Above error or program log occured at :12:30:05 29/06/05
ERROR: External exception C0000008 at time/date 12:31:00 29/06/05
Above error or program log occured at :12:31:00 29/06/05
Resetting rain daily value , day: 30
Above error or program log occured at :0:00:00 30/06/05
Resetting wind/temperature daily value , day: 30
Above error or program log occured at :0:01:00 30/06/05
Resetting rain daily value , day: 1
Above error or program log occured at :0:00:00 01/07/05
Resetting wind/temperature daily value , day: 1
Above error or program log occured at :0:01:00 01/07/05
« Reply #3 on: July 01, 2005, 06:25:03 AM »
are you running any antivirus software, like avg?
i see the last few days have been ok?
(i.e those errors were a few days ago now)
« Reply #4 on: July 01, 2005, 06:59:32 AM »
Running norton antivirus corporate 9...have been running this since the start with the la crosse. Could it be the drivers for the usb data logger maybe? The Davis was intalled on the 29th.
« Reply #5 on: July 01, 2005, 07:04:08 AM »
a usb driver problem would stop the data flow....but not shut down wd..I would not think..
i recommend to people to get the serial davis data logger, and then a USB to serial converter if no serial ports available on the pc
« Reply #6 on: July 01, 2005, 07:07:42 AM »
hmmmm sooooooooooooooo yeah?
What is this error?
But any more ideas on the WD shutdown?
« Reply #7 on: July 01, 2005, 07:27:09 AM »
those are not errors, but program event logs to say that the daily reset has occured
i.e they are normal.
if i removed that event log i am sure I would get complaints about them not being there any more  8O
« Reply #8 on: July 01, 2005, 07:31:49 AM »
hahaha yeah ok great u just can't win sometimes  :roll:...hmmm the only other thing was that I installed a windows update 'update' that automatically updates all critical updates when available...might give it the heave ho and see how it goes.
« Reply #9 on: July 01, 2005, 07:33:54 AM »
see if there is a pattern,..i.e always the same time...
« Reply #10 on: July 01, 2005, 07:49:03 AM »
yeah trying to work out a bit of a pattern but so far all over the place which is not helping.
« Reply #11 on: July 01, 2005, 07:53:59 AM »
just a quick note to mention that your dailylogout file needs a bit of work in 10.26t...all over the shop  :D
www.rainhailorshine.info/dailylogout.html
« Reply #12 on: July 01, 2005, 08:08:52 AM »
for that, zip and email me your log file, dailylog.txt
« Reply #13 on: July 01, 2005, 08:14:05 AM »
on the way...done.
« Reply #14 on: July 01, 2005, 08:49:25 AM »
ohhhhh
thats a bug thats going to be there until the 10th of the month  8O
uploading 10.26v zip now to fix that
it should be ready to download in less than an hour
