home now
been away
yes, i am getting the emails
try the latest beta/debug version, which should be redy soon, 10.27c
now, it wont now though email me the error, but if you are there when the error occurs, you will be able to copy/paste it to me instead (better in the long run)
now, is your PC under high cpu load at times?
can you try shutting down the virus scanning for a while as a test?
BUT
though, i think i know what it might be
have you in use the new daily log web page?
(dailylogout.html), in the web files/web page setup
if your dailylog.txt file is larger than a day in size, then that causes that error you see
(which i have fixed (hopefully) in the latest beta/debug and a new 10.27c version)
it must be that wd handling the davis station is more prone to not getting enough cpu than the 2315 station....
which windows version?
try allocating more cpu resoruces to wd (weatherd.exe ) maybe, via task manager
