9.34b hosed some records
these from the custom tags
32.0…Average temperature so far for the month
0.0…Average humidity so far for the month
-79.2…Average dew point so far for the month
0.000…Average barometer so far for the month
0.0…Average windspeed so far for the month
0.0…Average gustspeed so far for the month
0…Average direction so far for the month
32.0…Maximum temperature so far for the month
32.0…Minimum temperature so far for the month
0.0…Maximum humidity so far for the month
0.0…Minimum humidity so far for the month
-79.2…Maximum dew point so far for the month
-79.2…Minimum dew point so far for the month
23.624…Maximum barometer so far for the month
0.000…Minimum barometer so far for the month
0.0…Maximum av speed so far for the month
0.0…Maximum max gust so far for the month
the data is OK, dont worry there,its just not using the correct data file again for those tags generation
we have had this problem before, which I fixed, but fixing the frozen graph problem, i have stuffed this up again…
i will see about it
i have fixed, tested, and this is fixed for good now, promise
download and use a new version 9.34b now
yup, knew the data was still there, cause I’m getting pretty good at reading the .ini file! lol
and it’s fixed, and as usual, ‘you da man’ Brian!
