Brian has done a great job and WD now works with 1-wire using OWW to supply the information, this gets round the current comport problem crashing your server and no current 1-wire direct setup in Linux.
How To :
Oww can be sourced from http://sourceforge.net/project/showfiles.php?group_id=86628 download Oww and install on your Linux box.
Download the latest version of WeatherD and decompress into your wdisplay folder replacing (or change its name to be safe) the last WeatherD in your folder.
In your home folder open the .oww_setup file ( its a hidden file so tick show hidden files ) and amend the following entries as shown in #Format strings …logform
Format strings
displaydate %d/%m/%y %H:%M:%S
logfilef /%y%m/%y%m%d.csv
logdirf /%y%m
logform $trhc1%3.2$ , $rh1%3.2$ , $dp1%3.2$ , $bar1%4.2$ , $wsp%3.2$ , $wdrdeg%3.2$ , $rain%3.2$
logheadf
raintform Rain: %%s since %H:%M
raindform Rain: %%s since %d/%m/%y
lcdform
This is a copy of my set up but basically its TEMP, HUMIDITY, DEWPOINT, BAROMETER, WIND SPEED, WIND DEGREES, RAIN this supplies the data for the log file
Then go to the bottom of the file and enter the following in the # Log setup, this gives the log a name, mine is test.txt, test.txt is the file that supplies the data to WD.
Log setup
loginterval 5
logsnap 0
logtype 1
logfile_name logfile.csv
logdir_name logdir
logvar /home/stumpey/test.txt
font
Set logging in Oww to every second or in my case every 5 seconds.
Back to WD
Start WD then >setup >control panel>weather station type>stationless…in stationless you will see OWW custom file click Select input file and find your log file created by Oww in my case test.txt, tick the OWW box and Close. Remember to untick the stationless button
You should now see data flowing into WD from the file .
If you need help just PM or email me
Have fun
Steve
