cloudy
Author Topic: Post A Picture of the Setup for Your Weather Station  (Read 46881 times)
Offline wakarimasen
  • Bromsgrove, England, UK
Re: Post A Picture of the Setup for Your Weather Station
« Reply #45 on: March 21, 2005, 08:33:40 PM »
My Davis VP1 anenometer, mounted yesterday, from the side of our garage.
It's higher than it looks - garage is two storey - and I will not be enthusiastically anticipating a change of back-up batteries.
Only one problem: our house - to the SW - is about 10 feet higher  #-o
« Last Edit: March 21, 2005, 08:35:49 PM by wakarimasen »
tap tap tap ....
Offline aifan27
  • Tim
  • Pennsylvania
    • Newtown Weather
« Reply #46 on: March 21, 2005, 08:49:46 PM »
Thanks for the input, but I am not able to mount my anemometer on my roof.  Thanks for the help though...Would anyone else like to share?
Offline aardvark
  • I am perfectly calm,ready to hear your opinion
  • Des Moines, Iowa, USA
    • Des Moines, Iowa Weather
« Reply #47 on: March 21, 2005, 10:19:36 PM »
 :shocked!:Sounds good...but our association does not allow us to put anything on our roof or any concrete.
On the roof... probably because one house of many would look different, but the concrete?  buried in the ground?  under ground....  That is a bit odd.    With our association of sorts, we are trying to keep out the drug meth folks... oh well. concrete or meth labs?
So what happens if you dig a hole for the post, pour in some of that fast set stuff   throw dirt on top ?    I suppose there might be an excess calcium in the neighborhood sensor?     :o
VP2, Daytime Fars, Solar/UV; Soil station; extra temp/humid station; extra temp stations; Windows 7, 8G Ram , 1TB drive/external and Windows xp for weather data.
Offline aifan27
  • Tim
  • Pennsylvania
    • Newtown Weather
« Reply #48 on: March 21, 2005, 10:39:59 PM »
That's true...LOL...I will probably do something like that.
Online Weather Display
« Reply #49 on: March 21, 2005, 10:44:13 PM »
use guy wires possibly instead???
Offline aifan27
  • Tim
  • Pennsylvania
    • Newtown Weather
« Reply #50 on: March 21, 2005, 11:41:14 PM »
Good idea, but I really don't like the idea of guy wires...and anyways, I don't have very much space in backyard at all (only about 0.075 of aan acre, literally!...but maybe more), so there is not much room to put them.  Thanks for everyone's ideas though, and keep 'em coming!
Offline Kojack
  • North Gosforth Newcastle upon Tyne
    • North Gosforth Weather
« Reply #51 on: March 22, 2005, 03:25:52 PM »
Have you considered using an extension cable to resite your transmitter at a more accessible height for changing backup batteries?
John
XP Pro SP3
Offline aifan27
  • Tim
  • Pennsylvania
    • Newtown Weather
« Reply #52 on: March 22, 2005, 03:49:57 PM »
Well, what I am going to do is buy an 8 ft. 4x4 wooden post and bury it into the ground 3 ft. without concrete.  Then I will buy two 5' antenna masts that simply snap together and use clamps and such to attach them to the wooden post.  This will make the overall height about 12'.  And if I have to clean the anemometer, I can just take off one of the 5' antenna masts, which will then make it about 7' tall.
Offline wakarimasen
« Reply #53 on: March 22, 2005, 08:09:26 PM »
I did think about that, but being afraid of heights, and a masochist ........ :D
tap tap tap ....
Offline snowman
  • C'Mon Snow
  • North Central Pa USA
    • sterlingrun.com
« Reply #54 on: March 22, 2005, 10:51:28 PM »
That's exactly what I did - works great.
Offline aifan27
  • Tim
  • Pennsylvania
    • Newtown Weather
« Reply #55 on: March 23, 2005, 02:37:16 AM »
Snowman, what is the approx. height of the whole setup?  (including wooden post and antenna mast.)  Like 10 ft.?  12 ft.?  Let me know...Thanks.
Offline aifan27
  • Tim
  • Pennsylvania
    • Newtown Weather
« Reply #56 on: March 24, 2005, 12:45:24 AM »
Also, how sturdy is the whole thing...like does it stand strong in 30+ mph winds?  Thanks for your help.
Offline snowman
  • C'Mon Snow
    • sterlingrun.com
« Reply #57 on: March 25, 2005, 10:36:42 AM »
It is a 10' mast - 1 5' put together.
I fastened the entire pole to the post, which leaves about 6' extended above.
The mast from Radio Shack is very sturdy - you'll be suprised at how heavy it is.
Anyway, the post is in the ground around 3', and above the ground about 5'.
The mast is 10' above the ground.
Have to run to work now - I'll answer any questions you have later if you have any.
Offline aifan27
  • Tim
  • Pennsylvania
    • Newtown Weather
« Reply #58 on: March 25, 2005, 06:37:49 PM »
Would you happen to have any other pictures of the opposite side, so I could see how you attached the antenna masts to the wooden pole?  Thanks.
Offline snowman
  • C'Mon Snow
    • sterlingrun.com
« Reply #59 on: March 25, 2005, 08:02:46 PM »
I'll take one tomorrow and post it -
I went to an electrical/plumbing supply, and bought simple u-clamps with two hold to attach to the post.
I'll describe more with some photos tomorrow (off to the local tavern for a pint or two).
