cloudy
Author Topic: Post A Picture of the Setup for Your Weather Station  (Read 46906 times)
Offline dendrite
  • Northfield, NH
    • Eastern US Weather Forums
Re: Post A Picture of the Setup for Your Weather Station
« Reply #180 on: August 25, 2006, 09:22:31 PM »
I've waited for this day, but everything is finally sited and pics have been taken.
The pics are of my Davis VP2 Plus w/ FARS, my Leaf/Soil station with leaf wetness, soil moisture, and soil temp, and my anemomter on a roof tripod and telescoping mast about 35-40ft off the ground using the wireless transmitter.
All of the pics are over at Wunderground...
http://www.wunderground.com/wximage/viewsingleimage.html?mode=singleimage&orig_handle=dendrite5478&orig_number=15&handle=dendrite5478&number=0&album_id=0#slideanchor
Offline looney2ns
  • Fearless Weather Dog-Loves to watch Lightning.
  • Near Evansville Indiana USA
    • Newburgh Weather
« Reply #181 on: August 26, 2006, 01:19:56 AM »
Please edumacate me. Whats FARS?
Offline dendrite
  • Northfield, NH
« Reply #182 on: August 26, 2006, 01:23:38 AM »
FARS = fan-aspirated radiation shield :)
Offline looney2ns
    • Newburgh Weather
« Reply #183 on: August 26, 2006, 01:25:56 AM »
AHH! That I understand!  :D
Thanks!
Offline hydrowx
  • Bill
  • Northeast Illinois USA
    • Goose Lake Weather
« Reply #184 on: August 26, 2006, 12:37:06 PM »
Nice setup. Great job!  :)
Bill
Offline Foggy
  • Foggy Hamilton, NZ
    • Hamilton NZ Weather
« Reply #185 on: December 27, 2006, 08:40:37 AM »
Here's a couple of my setup with the solar sensor along the middle of the roof and the Boltek above the anenometer. (thanks to ricky in the latter)  :)
Click to open..
Would be great to see more setups!  :D
Offline fairweather
  • Andy
  • Worcester, Midlands, UK
    • Worcester Weather Station
« Reply #186 on: December 29, 2006, 06:14:51 PM »
hello there i have just joined this forum, as i have just upgraded to a DAVIS VP2 wireless from a Lacrosse ws2500.
What a beautiful peice of kit the Davis is  :lol:.
Heres a few pics of it installed
(i must take that warning sticker off  :roll:)
The Anenometer is a good 3-4 meteres about the rooftop, and was a little hair-raising trying to put it up. You can see the old la crosse sensor beneath it.
Again the old lacrosse LUX sensor which is on the lower roof.
« Last Edit: December 29, 2006, 06:23:31 PM by worcesterweatheruk »
Offline looney2ns
    • Newburgh Weather
« Reply #187 on: December 29, 2006, 07:56:14 PM »
You will find that the brown fence will most likely artifically raise your temps when the sun hits the fence.
Offline fairweather
  • Andy
« Reply #188 on: December 29, 2006, 10:33:08 PM »
That area is always in shade, but thanks anyway  :)
I see quite a few of you guys in the states have Boltek systems, im saving up for one of these at the moment. Although here in the midlands we dont get as many of you out there it would still be nice to see storm devlopment in realtime  :D . Shame that most weather equipment is alot more expensive over here though  :(
« Last Edit: December 29, 2006, 10:51:44 PM by worcesterweatheruk »
Offline SoftWx
    • SoftWx
« Reply #189 on: December 30, 2006, 05:15:33 AM »
ISS looking southwest
ISS looking east
Anemometer looking north
ISS and anemometer in relationship, looking east
Offline Chaser80
  • mmmmmm hail:)
  • Perth Western Australia
« Reply #190 on: April 09, 2011, 06:43:18 AM »
aint looked at this in ages, heres my setup page www.tkup.net/data/info :)
Offline mckTXaws
  • Weather isn't just a hobby, it's a passion!
  • Under the weather? Were on top 24-7-365!
  • McKinney TX
    • mckTXaws
« Reply #191 on: April 24, 2011, 04:08:38 PM »
My weather station tower which supports my WMR100, Vantage Pro2, and WS-1910U-TWC is about 25 Ft un-tethered, and has stood up to 50-60 MPH winds. This uses a 15 Ft  Aluminum telescopic pole which can be found at Lowes in a kit for 45$, and an additional 10 Ft steel mast which can be found in the metal fencing for about 8$.
Here are some photos of my station.
« Last Edit: April 24, 2011, 04:11:06 PM by mcktx101 »
HUKUNA MATATA! No worries!
Offline niko
  • syzygy
  • Global Moderator
  • Northern California, U.S.A.
« Reply #192 on: April 24, 2011, 06:01:12 PM »
Very nice. Do you have some more info about the lowes telescoping pole kit, e.g. what department it's in or its intended use?
Offline mckTXaws
  • McKinney TX
    • mckTXaws
« Reply #193 on: April 24, 2011, 08:06:47 PM »
The telescoping pole would be found in the birdhouse section. It will be sold in a 3 Ft long white with purple writing box labeled, "Purple Martain House pole." The pole has 4 of these sections. What you do is, the pole sections slide into each-other. And there are a set of lock pins included. These slip into the channels on the sides. And when the station is mounted, you can raise it and when you need to take it down, pull out the pins and lower it. The instructions say to use concrete, but if you tether it, this isn't nessisary. For my backyard, there was alreasy a concrete hole from an old fence post that I was able to take advantage of. One other thing I have done with mine for safety, if if you tether it, take some string and a steak, tie the other end of the string to the pins, that way if the winds get too high the string pulls the pins out and the station can lower to a safer height. The steel fence post can be found in the cross wire fence area under the buildings roof around the pool supplies area. They also sell other hardware there than can be helpfull in the setup process. The steel fence poles have slide in ends. The steel pole will become unstable if to high. The top of the telescoping pole has an outside diameter of 1-2 inches so find a fence post that measures close to this. You might need some 3 inch long deck screwes to tighten it.
Offline mckTXaws
  • McKinney TX
    • mckTXaws
« Reply #194 on: April 24, 2011, 08:12:47 PM »
Lowes doesn't have it on their web site, but here is another resourceful web site that has it You can still find it at Lowes for 45$ so don't let the 59.99$ catch you. Heath, the manufacture doesn't seem to have a website.
http://www.birdsanctum.com/product/HE-MP15
