Wind data lost
As soon as I updated to 9.27d, all the values for
Average Windspeed This Month
Average Wind Gust This Month
High Average Wind Speed This Month
Average Wind Direction This Month
were all reset to 0
also, my average temperature this month now reads 32.0
also! the font on the trends.gif has changed and is really weird now!
I rolled back to 9.27a and everything is back to normal. Sorry for all the individual messages, but since we can’t edit our messages anymore…
i think it was adding the trend comparison for last month and last year
i.e the data file to use for the averages is being bunged up
are you refering to the custom tags?
i have added a routine to teh close of the trends to reset the current data file to this month
please try 9.27e
and let me know if that fixes it :slight_smile:
I should have specified…yes the custom tags were showing 0 on my page. But sometime during the night, they started showing the correct data! and it was not during the 1200 am reset either, because I checked around 1230.
it would have bee a routine in the averages/extreme that loaded the correct month data into memroy to use
is the latest verison still doing this?
it seems to be ok now. sometime between 1230 am and 730 am it started putting the data back in the custom tags.
Average Temperature This Month
are now displaying correctly o
vers 9.28 should be much better for this now :slight_smile:
just checked my page… the custom tags for
Average Windspeed This Month = 0.0
Average Wind Gust This Month = 0.0
High Average Wind Speed This Month = 0.0
Average Wind Direction This Month = -0
Average Temperature This Month = 32.0
which are the same readings that occured when I first upgraded from 9.27a.
for some reason they stopped working after about 12 hours.
if you go to graph history, it fixes it up…(and you force the wx file to update via teh advanced file management)…
its the new month and year comparison in the tends that is causing the problem
trying to fix now…
fixed
uploading 9.28b now (and it fixes the windspeed comparisons in the trends)
I also noticed it’s affecting the trends.gif. Since it thinks the average temp this month is 32.0, and the current temp is 68.0, the trend for today is +36.0 degrees.
new one ready now, should be a ok , 9.28b
