Author Topic: 1-wire Lightning Dector - Actual Attempt  (Read 90120 times)
0 Members and 3 Guests are viewing this topic.
Offline JaxWeather
  • Bob
  • WML Station: WD00007
  • Jacksonville, Fl. USA
    • JaxWeather.net
« on: February 26, 2005, 04:36:10 PM »
I figured I would start a new thread in regards to the actual "attempt" to install the Hobby-Board 1-wire lightning detector and associated items...
For anyone that missed it, this thread got things started with me trying this...
I got the USB 1-wire adaptor late yesterday, actually I don't know when I got it as I saw a box on a bookshelf and asked what that was and one of my "Darling" daughters said Dad that was delivered a while ago... Grrrrrrrrrrrrrrrrrr  LOL
So today I have some quiet time (means Boss and daughters are out for a few hours and the Music is cranking on my new Onyko Stereo System :) ) so i am going to try and do a test hook up.  I read that you can set it up and touch the antenna lead to the earth ground and if working get "hits"...
I download the drivers from here:
http://www.aagelectronica.com/aag/index.html
Install_1_Wire_Drivers_v400b3.exe
I install and I am prompted to install .NET framework 1.1 which I do...
Available here: http://msdn.microsoft.com/netframework/downloads/updates/default.aspx#.NET%20Framework%201.1%20Downloads
 I get same prompt after installing so i reboot...  I still get same prompt and then I realize it isn't actually the same prompt, but the link takes me to same place...
It was a second prompt to install: Visual J# .NET which I get and install, this download is located here:
http://msdn.microsoft.com/vjsharp/downloads/howtoget/default.aspx
Ok now the install for the drivers goes swimmingly and all says is OK...  It still cannot detect 1-wire adaptor, so i reboot again, as noted in the readme.  This time after rebooting it is detected and I think all is well...
BUT I can get no readings anywhere, tried OneWireViewer Application, tried WD setting up Lightning detector and all No-Joy :(
I really would like to test this thing before I go and make it's permanent home and run 50' of wire and drive in a three foot deep ground spike...
Anyone have any ideas?
Bob
Re: 1-wire Lightning Dector - Actual Attempt
« Reply #1 on: February 26, 2005, 05:49:58 PM »
hi
check in windows control panel, device drivers, for the usb adaptor and it should say there what port number it is on...
mine ended up being as port number 1...which is not to be confused with com port 1
in wd, in the com port setup, you will need to tick, i want to use a dallas 1 wire, then tick, usb,then set the com port number to 1 in that , i want to use a dallas 1 wire, then tick, i do not have a temperature sensor
then click on ok
then go to setup, control panel, dallas 1 wire setup, and click on save/reset
and you should see the 1 wire ROM id counter
Offline JaxWeather
  • Bob
    • JaxWeather.net
« Reply #2 on: February 26, 2005, 06:19:22 PM »
Hi Brian, Fancy meeting you here :P
I will try those suggestions on my next attempt to get this tested, prior to full installation.
Right now my system doesn't seem to recognize the 1-wire sensor or adaptor at all so i will most likely have to uninstall and try from scratch... which may not be today as it requires (or has so far) a reboot to get it installed...
Will keep this thread posted...
« Reply #3 on: February 26, 2005, 06:24:36 PM »
yes, its a shame so many reboots a required for those driver installs....1 more might do it
actualy, just checking my device manager, it lists it at the top, under 1 wire deives
but does not say what port number
but the i button viewer reports USB1 down the bottom left hand corner,. hence the 1 needed for port  number
Offline JaxWeather
  • Bob
    • JaxWeather.net
« Reply #4 on: February 27, 2005, 06:03:51 PM »
Okay....
I got to that, but unless there is something else I am missing I get no incremental counts when testing by crossing Antenna Lead to Main Earth Ground so I have no clue if it is actually working?
I see where you are to enter specific IDs for specific tasks , wind, temp and so on BUT no Lightning field...
Offline 41South
  • Colin
  • Strathmore, Wellington, NZ
    • 41south.net.nz
« Reply #5 on: February 27, 2005, 06:33:14 PM »
Quote
There is a tab along the top for the lightning detector. Copy and pasted the rom id from the list window in there and then do a reset/save.
Testing is best done with a spark source, like a gas fire lighter or similar.
Cheers, Colin.
Dallas 1-wire v3.0, Lightning, Humidity, Rain, Solar, Pressure, Temp sensors. Member of the Lightning Radar project.
« Reply #6 on: February 27, 2005, 06:41:51 PM »
now that you have a 1 wire Jax weather, and now that i have the 12 volt 1 wire switch working in wd (latest version of wd now had a sheduler ), you can get WD to turn things off and on.,....like turn the coffee machine on ....turn of the or irrigation, set things based on temeprature ranges (i am still to add that), even get a leaf wetness sensor and wd could turn something on or off as soon as it starts raining, etc
Offline JaxWeather
  • Bob
    • JaxWeather.net
« Reply #7 on: February 27, 2005, 06:48:19 PM »
I tried that, there are 3 question marks in the field "???" and no matter what I try it will not allow me to enter...  I paste and it shows but then disappears.  I also am unable to erase the "???" nothing works...
I wish I had 1-wire Brian...  either something still isn't right in WD OR my Lightning Detector ain't working :(
Offline 41South
  • Colin
    • 41south.net.nz
« Reply #8 on: February 27, 2005, 06:52:45 PM »
Quote
No no.....thats for the direction indicator on older 1-wire versions. You need to select the Lightning tab (along the top of the window) in the 1-wire setup.  :)
Cheers, Colin.
Offline JaxWeather
  • Bob
    • JaxWeather.net
« Reply #9 on: February 27, 2005, 06:59:41 PM »
Yes yes... YES
That was the ticket... Tested with spark fire lighter and BOOM  It works !!!
Thank you :)
Ok now to get in set up outside and functional...  which won't be today or tomorrow as it is miserable out there today  LOL (just my luck)
Thanks 41South and Brian :) :)  :D
Kewl!
Offline 41South
  • Colin
    • 41south.net.nz
« Reply #10 on: February 27, 2005, 07:02:19 PM »
Excellent - pleased to be of service.  :thumbright:
Cheers, Colin.
Offline Ed1
« Reply #11 on: February 28, 2005, 02:51:05 PM »
Jaxweather...you had me worried  :)   I'm going to follow this thread in getting mine setup.
Going to send away for my parts this week.,    Which cabling are you going to go with ?
The Cat5  or Telephone cable?
Offline JaxWeather
  • Bob
    • JaxWeather.net
« Reply #12 on: February 28, 2005, 03:49:13 PM »
Hello Ed,
Actually I was going to use the twisted pair stuff from Radio Shack however I discovered (along with my RJ crimpers) I had some 6 wire shielded cable (flat) laying about and I am going to try that first...
If you have to buy stuff I would think the Cat5 would be best followed by the twisted pair cabling however that is an assumption on my part.
I have submitted a FAQ to the "Powers that be" regarding installing the USB adaptor and setting the Lightning Detector up in WD and if approved will eventually be added to the FAQ section...
Will post more later in the week when I actually get it installed outside in production...
Offline Ed1
« Reply #13 on: February 28, 2005, 04:50:47 PM »
Hello
Thanks for getting a fact together for the setup, it'll be a great addition.
Also remember..you can assign a Wav file to your lighting hits for an audible alert.
Offline JaxWeather
  • Bob
    • JaxWeather.net
« Reply #14 on: February 28, 2005, 04:53:17 PM »
I did forget that and will do that when in production...  Thanks again,
Bob
