Okay....
I just finished the final installation...
Materials...1 10' 1 1/4" PVC pipe section
3 End caps
1 1 1/4" Tee
My Hygo-thermo sensor is mounted on a 2X4 on the side of my house (north side) and for a number of maintenance reasons I didn't want to mount the lightning detector directly off the 2X4 I went ahead and just cut the PVC pipe so that the top section was just the right length for the antenna and some wire.
Then I cut about 5" of PVC pipe from the bottom for a dogleg out from the Tee.
When all completed I had...
- <== Cap
| <== antenna
L <== Sensor and battery lay in 5" dogleg | <== cap with hole for the wires to exit from
| <== bottom section
- <== cap
The ground rod is 5/8" galvanized ground rod buried 9' deep
Pictures can be seen here:
http://JaxWeather.net/Gallery/thumbnails.php?album=4I ran the wire to the USB adaptor then pressed "Save/reset" in the Dallas 1 wire setup/info page an Boom there it was.
I went back outside and took my trusted gas lighter, flicked it a couple of times, came inside and there was the indication of two hits.
Now for a thunderstorm to see what happens, and of course watching for false strikes...
All in all I spent under $100.00 USD including all wiring, connectors, PVC, ground rod, lightning detector and USP 1-wire adaptor.
Beats $350.00 + for the package options, even though it has no mapping abilities. Coupled with WD I can see hits and frequency of hits which should be a fairly good indicator if I need to hunker down LOL
