I may be wasting my time replying to a spammer but maybe someone can use the info.
Not sure whether this has/was discussed in the old forum or not.
This is a three-part question:
1) Has anyone built their own lightning detector? I have found a couple links via a Google search but they are all in Europe.
Depends what you mean by "detector", there are many simple detector designs, they just detect strikes without range or bearing information. If you want range and bearing there are two diy options that I know of:
blitzortung which is European and has a website that collates data onto a map.
Frank Kooiman's system also Europe based but with members elsewhere.
2) If so, where did you get the information on building it?
See above for those two, for simple detectors
Hobby Boards has kits which interface to a PC, or sites like
http://www.techlib.com/ have general construction info.
3) Since they can be built (Europe is doing it quite successfully from what I have read), can any of the outputs be used with the existing lightning collection sites?
See #1.
http://www.strikestarus.com/ collates data from Boltek detectors in the U.S.
