cloudy
Author Topic: Build a lightning detector  (Read 88492 times)
Offline 41South
  • Colin
  • Strathmore, Wellington, NZ
    • 41south.net.nz
Re: Build a lightning detector
« Reply #105 on: February 24, 2005, 11:24:15 PM »
Quote
DS PCB!
That took me a while ......DS = double sided  :lol: :lol:
I'm getting slower in my "old" age.
Cheers, Colin.
Dallas 1-wire v3.0, Lightning, Humidity, Rain, Solar, Pressure, Temp sensors. Member of the Lightning Radar project.
Offline 41South
  • Colin
    • 41south.net.nz
« Reply #106 on: February 24, 2005, 11:30:46 PM »
Quote
Now... Where does "D GND - data ground" go?  Does it connect to the USB 1-wire connector, get split off before and connected to the actual computer box?
The Data wire needs to end up on what post when plugged into the USB 1-wire adaptor, far left or far right AND will CAT 5 cable and connector work for this?
1-wire needs 2 wires  :roll: data and data ground. CAT 5 is fine and dandy, but you need to use it with RJ11/12 connectors - not RJ45s
The USB 1 -wire adapter uses the middle 2 pins of the connector - 2&3 for the RJ11(4pins), 3&4 for the RJ12(6pins).
Pins 2 is data and pin 3 is grnd on the RJ11, pin 3 is data and pin 4 is ground on the RJ12.
I'll dig up some connector pics and post them too.  :)
Cheers, Colin.
Offline JaxWeather
  • Bob
  • Global Moderator
  • WML Station: WD00007
  • Jacksonville, Fl. USA
    • JaxWeather.net
« Reply #107 on: February 24, 2005, 11:34:56 PM »
Ahh Colin that was exactly what I needed :)
I have some RJ-12 connectors I can replace the end on a CAT 5 Cable with :)
I assume that since you Indicate that 1-wire needs RJ-11/12 connectors that twisted pair telephone cable would also be suitable?
Thank you and as soon as I get the USB adaptor I will be seeing what damage, Errrr what I can get going ;)
Thanks again,
Bob
Offline 41South
  • Colin
    • 41south.net.nz
« Reply #108 on: February 24, 2005, 11:41:12 PM »
CAT 5 is still your best bet, although it can be a bit fidly getting it into the RJ11/12s nicely.
Here's the link to the USB adapter manual, the connection details are in there.
http://www.aagelectronica.com/pdf docs/DS9490R.pdf
Happy building
Cheers, Colin.
Offline JaxWeather
  • Bob
  • Global Moderator
    • JaxWeather.net
« Reply #109 on: February 24, 2005, 11:50:55 PM »
Well now who woulda thought that the folks I ordered the USB adaptor from would have detailed instructions for the adaptor Oyyyyyyyyyy  #-o
And here I was searching all over the place for this information.
Thanks again Colin this additional information will prove to be invaluable :)
Offline JaxWeather
  • Bob
  • Global Moderator
    • JaxWeather.net
« Reply #110 on: February 28, 2005, 01:36:50 PM »
Ok just as a final (i hope) follow-up to this thread...
I have received the components and have assembled and tested them, so far.  Later this week i will be placing the lightning detector in production.
My personal saga in installing and testing the lightning detector is continued here:
http://www.weather-watch.com/smf/index.php/topic,8047.0.html
For anyone that wants to see what I did to get to this point :)
Offline PicOlio
  • It all started with a turtle pond...
  • Oviedo FL
    • http://www.PicOlio.com
« Reply #111 on: March 28, 2005, 11:28:01 AM »
Quote
The one that "allows me to spend" is the one I have to worry about seeing the posts...  The one that "Pays the Money" well she will just blackmail me if she sees these  LOL
In my jealousy of his fancy dancy new lightning detector I came sneaking around to see what other info there is and find all this talk about "the boss" -- well let it be known I'm just "a boss" (more of a friend though)... his wife is "THE BOSS" :P and their lightning detector seems to be working out rather nicely indeed!  I'm just trying to figure out how to "do one better" ...
If I could get a web cam to be triggered by the lightning detector thereby ensuring pictures of the lightning that is being detected.... hmmmmmmmm
Florida
"The Sunshine State"
« Reply #112 on: March 28, 2005, 05:05:00 PM »
I wondered if you would stumble on his Boss posts Picolio, LOL!
ohhh lalala, as Jazweather would say
yes, i think the wife is the boss in alot of relationships!
Offline fkooiman
« Reply #113 on: July 15, 2006, 08:36:14 AM »
Hello,
We are working for a while now on a europees network for lightning detection.
The basic principle is that is should be simple and low cost.
Take a look at :
http://members.home.nl/fkooiman/lightning
I'll be happy to answer your questions.
Frank Kooiman
« Reply #114 on: July 15, 2006, 08:58:36 AM »
yes, very interesting what you have been doing!
we have seen your web site and have discussed what you are doing before....I know some here are quit keen on trying it out....
Offline JoeDuggins
« Reply #115 on: August 28, 2009, 01:14:36 PM »
Not sure whether this has/was discussed in the old forum or not.
This is a three-part question:
1) Has anyone built their own lightning detector? I have found a couple links via a Google search but they are all in Europe.
2) If so, where did you get the information on building it?
3) Since they can be built (Europe is doing it quite successfully from what I have read), can any of the outputs be used with the existing lightning collection sites?
Sorry for all the questions but I thought others may be interested in some way to get into the lightning detection game without having to shell out hundreds of $$$.
Money without intelligence is like a car without a road.
[unrelated commercial link removed]
« Last Edit: August 28, 2009, 01:34:18 PM by niko »
Offline niko
  • syzygy
  • Global Moderator
  • Northern California, U.S.A.
« Reply #116 on: August 28, 2009, 01:45:09 PM »
I may be wasting my time replying to a spammer but maybe someone can use the info.
Depends what you mean by "detector", there are many simple detector designs, they just detect strikes without range or bearing information. If you want range and bearing there are two diy options that I know of:
blitzortung which is European and has a website that collates data onto a map.
Frank Kooiman's system also Europe based but with members elsewhere.
Quote
See above for those two, for simple detectors Hobby Boards has kits which interface to a PC, or sites like http://www.techlib.com/ have general construction info.
Quote
See #1. http://www.strikestarus.com/ collates data from Boltek detectors in the U.S.
Offline TokKiwi
  • Techno Dad
  • Mech Engineer and Hobbyist
  • Tokoroa, Sth Waikato, New Zealand
    • Tokoroa North Weather
« Reply #117 on: August 28, 2009, 08:34:02 PM »
Fair comments Niko and good support.  Another link for the Lightning radar projects of Frank Kooiman and project partner Daniel, is Daniel's website here... http://users.edpnet.be/DanielV37/Detecteur3/index_full.htm where the hardware and basic designs are from.  He also designed a preamp for the unit but whuch is no longer in production.  There is another preamp available out of UK from John Silver I think.
There are folk who have linked here in the forum, I think that have made Lightning detectors and camera triggers if that was more to the point.  Try here... http://www.techlib.com/electronics/lightningpics.htm
The project above (and which I run)  needs a partner station to correlate and triangulate the position of a particular strike.
TK
(Added some more details)
« Last Edit: August 28, 2009, 08:43:22 PM by TokKiwi »
Dad's have hobbies because they are children's rugby, football and Committee Fathers!!
Offline niko
  • syzygy
  • Global Moderator
« Reply #118 on: August 28, 2009, 08:38:02 PM »
Thanks for the link Graeme, I knew there was another site for Frank's stuff but a quick google didn't turn it up this morning  :)
