cloudy
Author Topic: Javascript advisory scroll  (Read 31796 times)
Offline labwizard
  • Pisgah Forest, NC
    • My Weather page
Re: Javascript advisory scroll
« Reply #45 on: March 09, 2005, 12:21:24 PM »
Bob,
     YOu've been a big help and along with Brian's programming wizardry the WD "standard" pages look much better. I am still inclined to do custom's but I want to understand how this is all done first then I have to find the time. Time is the biggest problem as I have to rob it from my wife and after she is home most of the day and I work, burying myself in a computer is not a real option. I usually take a Sunday afternoon to do this stuff but ACC tourney and the NCAA'a are coming up and you do have to have priorities.
Thanks again for the help,
Dave
Offline JaxWeather
  • Bob
  • Global Moderator
  • WML Station: WD00007
  • Jacksonville, Fl. USA
    • JaxWeather.net
« Reply #46 on: March 09, 2005, 01:31:31 PM »
You are more than welcome, just glad i could help at all :)
Tell me about Sundays...  Yard Work, NASCAR, NFL...  Sundays are the busiest day of the week for me many weeks  LOL
Offline labwizard
  • Pisgah Forest, NC
    • My Weather page
« Reply #47 on: March 09, 2005, 03:23:37 PM »
Tom,
     I'm simply using the WD "default" set up so I can't help too much. I believe you have to set that variable in CUSTOM SCREENS but that's as far as I've gotten. It looks like you're using your own custom's so Bob or someone else will have to help you. I'm taking baby steps so I don't mess it up. Good luck.
Dave
Offline TomTc
  • Granada Hills, CA, USA
    • The Tcimpidis Weather Station
« Reply #48 on: March 09, 2005, 03:29:36 PM »
I was actually going to use WD's built-in code but it does not work for me so far,  so I can not.  It appears to be a problem with the way that the "No Warning" field for my area is sent by NOAA, as it is different than the "No Advisory" that others apparently receive...  Plus, the code that is posted here has some features that Brian's does not yet have...
Tom,
Offline JaxWeather
  • Bob
  • Global Moderator
    • JaxWeather.net
« Reply #49 on: March 09, 2005, 03:55:22 PM »
Tom,
What zone?
Can you provide the actual difference you are seeing in yours that you believe is messing up the NOAAEvent tag?
Poor Brian has worked on the NOAAEvent back and forth trying to cover everything that NOAA uses... you would think they could standardize... :roll:
Online Weather Display
« Reply #50 on: March 09, 2005, 03:57:19 PM »
in the webfiles/webpag setup, tick, to use custom tags in the default web page...
Offline JaxWeather
  • Bob
  • Global Moderator
    • JaxWeather.net
« Reply #51 on: March 09, 2005, 04:34:35 PM »
That would be the same as mine (text wise) and I used your zone file and all appeared nominal...
I think Brian's suggestion may be the tip needed here?
« Reply #52 on: March 10, 2005, 02:59:00 AM »
the problem with my scroller code:
i was splitting up the long lines...
and so there are CR
i will change that
Offline TomTc
« Reply #53 on: March 10, 2005, 04:19:53 AM »
I enabled it per Brian's suggestion but it still doesn't work for me, alas...
Offline JaxWeather
  • Bob
  • Global Moderator
    • JaxWeather.net
« Reply #54 on: March 10, 2005, 04:32:52 AM »
There is a problem with the current javascript (for CarterLake's version) and Brian said he will be uploading a new Full 10.23d that will contain a fix soon...
I am bailing for the night but will check as soon as I can in the AM for the new full and test then...
« Reply #55 on: March 10, 2005, 08:31:04 AM »
i have done a test (surprise)
and its working now (in IE anyway)
uploading a new 10.23d zip now
Offline labwizard
  • Pisgah Forest, NC
    • My Weather page
« Reply #56 on: March 10, 2005, 10:50:19 AM »
Brian,
    It's partially working, I see a beige box, with "-..click here for more" trailing. Click it does go to the proper page I set. It's jsut the title is missing.
Disregard the above Brian, it's working fine, didn't give it time to show up. Now if it was just centered...
« Last Edit: March 10, 2005, 12:04:42 PM by labwizard »
Dave
« Reply #57 on: March 10, 2005, 04:01:13 PM »
i need to save the last noaa warning event, so that shows on restart
so if i added <center> </center> that will fix that ?
i notice it was ok in IE
but FF got its nickers in a twist
« Reply #58 on: March 10, 2005, 04:45:59 PM »
10.23e zip out soon, which uses the mylocation for the java scroll
and also the noaa event is now saved in the ini file so its still there when you restart wd (after the next restart of that version)
Offline labwizard
  • Pisgah Forest, NC
    • My Weather page
« Reply #59 on: March 10, 2005, 05:27:18 PM »
Brian,
    I'm at work but here is a shot of what I see on my site. I've also lost a gif but I'll have to troubleshhot this PM.
thanks, I love the way it works otherwise and looks much neater.
Dave
