TomTc
Senior Forecaster
OfflineLocation: Granada Hills, CA, USA Station Type: Davis 6161 VP Plus FARS
Posts: 375 Local Time: Thursday 09:46
« Reply #30 on: March 06, 2005, 04:08:14 PM » |
I vote for the new scheme, eve though it still does not work for me here, but perhaps Brian could make the two different methods user selectable if that is a concern... Brian, I am not sure you want to remove what is available now as some folks may like that...
If the datahtm1.txt file isn't editable then I am not sure what options there would be for those using the default pages. If it is able to be edited then we need a FAQ on how to remove what is currently available and replace with Tom's code...
I am always hesitant to suggest changing something that isn't broke for the sake of better and newer as not everyone always agrees that Newer - Better is really better as they get used to certain things...
« Last Edit: March 09, 2005, 01:35:03 PM by Tom T »
Logged
JaxWeather
Bob
Senior Weather Controller
OfflineLocation: Jacksonville, Fl. USA Station Type: Vantage Pro 2 w/ FARS + 1-wire Lightning - Logitech Pro 5000
Posts: 10,279 Local Time: Thursday 13:46
MML Station: WD00007
« Reply #31 on: March 06, 2005, 04:18:37 PM » |
I would think making it selectable in some fashion would be optimum, and I agree i far prefer the New CarterLake version myself, however being around apps for some years I have seen some loud cries and moans when something was replaced with newer/better when the original wasn't broke... Of course those that are happy with the Old method may be the ones that aren't upgrading often either and that may make a difference as well... -Bob
Logged
windy
Brian
Climate Controller
OfflineLocation: West Coast Road, Awhitu Peninsular, New Zealand Station Type: Davis VP, Mac
Posts: 58,203 Local Time: Friday 06:46
« Reply #32 on: March 06, 2005, 07:09:50 PM » |
i am not still not clear on what i need to do/change
also, though, someone wanted canada supported who knows information on that?
Logged
JaxWeather
Bob
« Reply #33 on: March 06, 2005, 09:37:20 PM » |
Cool... Our RED FLAG WARNING has changed to a WATCH and CarterLake's new code switched colors as advertised http://www.JaxWeather.net/Agian, Thanks Tom for a great script... -Bob
Logged
labwizard
Senior Forecaster
OfflineLocation: Pisgah Forest, NC Station Type: LaCrosse WS-2310
Posts: 357 Local Time: Thursday 14:46
« Reply #34 on: March 08, 2005, 12:26:58 PM » |
It would be great if Brian added this scroll. I fooled with it myself but was afraid I'd make too much of a mess and promised Brian no more problems for awhile after the past weekend of fixes.
Logged
Dave
JaxWeather
Bob
« Reply #35 on: March 08, 2005, 03:49:02 PM » |
If you are managing your own datahtm.txt files you could add it to your current page, just can't replace the top portion of the page as it appears that we cannot manage the datahtm01.txt file, but you should be able to add it to your page by adding the script code to your datahtm0.txt. If added directly below your "BODY BACKGROUND" tag in the datahtm0.txt file it will appear on at the very top of your web page. Test of concept can be seen here... http://www.jaxweather.net/WeatherImages/WD/index.htm-Bob
Logged
labwizard
Senior Forecaster
« Reply #36 on: March 08, 2005, 03:57:43 PM » |
Jax,
I'll give it a try (maybe this evening). I guess I'll have to make a NOAA events tag page to post is that correct? I still have not tackled the Custom Page setup.
« Last Edit: March 08, 2005, 04:05:55 PM by labwizard »
Logged
Dave
windy
Brian
Climate Controller
« Reply #37 on: March 08, 2005, 04:17:49 PM » |
hi but i already have a tick to add /use that scroller warning system, and you can set the URL to link to in a new 10.23c
Logged
JaxWeather
Bob
« Reply #38 on: March 08, 2005, 04:37:27 PM » |
in a new 10.23c  As in new now and ready for download or...? -Bob
Logged
labwizard
Senior Forecaster
« Reply #39 on: March 08, 2005, 04:42:28 PM » |
I thought I saw it when I updated Sunday but I was afraid to try it. So it was on the 10.23C that is current (at least in the ZIP).
Logged
Dave
labwizard
Senior Forecaster
« Reply #40 on: March 09, 2005, 02:00:53 AM » |
OK, I ticked the box for the scroll, added a URL for the warning page. The page still looks the same. Big warning box same as before, what did I miss?
Logged
Dave
windy
Brian
Climate Controller
« Reply #41 on: March 09, 2005, 02:06:30 AM » |
ok, i actualy did not find time to check this i will do that soon
Logged
JaxWeather
Bob
« Reply #42 on: March 09, 2005, 02:27:27 AM » |
You have to "Untick" "Include in my default WD web page"
Then after it updates the Java box will be gone. If you have no warnings or advisories you can view the raw source code of the page on the web and see the New scroller code...
Logged
labwizard
Senior Forecaster
« Reply #43 on: March 09, 2005, 11:24:44 AM » |
The "unticking" worked. Now to see what happens with and advisory. Thanks for the help Tom. I linked mine to the Hazard Warning Noaa page is that right?
Logged
Dave
JaxWeather
Bob
« Reply #44 on: March 09, 2005, 11:44:59 AM » |
That would be the link you want to include so that if someone clicks on your Warning scroller they are taken to additional information. My link is http://JaxWeather.net/JaxWeatherWarning.php while Tom uses a custom WD generated page wxlocal4.html which when uploaded is named wx4.html. http://www.carterlake.org/wx4.htmlYou can make the link anything you want, to your Local NWS main page or a custom page. Hope this helps, Bob
Logged
