We’ve tried everything to resolve this ftp problem. Right now, Gregg (Anything Weather) is checking with Brian (WD) for a solution. Anyone out there have any ideas??? #-o
Start Time/date:12:51:56 PM 1/11/2005
Permanent connection selected
Checking for what else to do…
there are 1 more things to do
Starting FTP transfer Now to anything weather server
Logging onto anything weather FTP server…66.37.155.80
Connecting to FTP server.
Failed to connect: [10061] Connection refused
FTP error occured
FTP error, looking for next agenda item
10061: [10061] Connection refused
Remote directory…weatherdisplay
FTP error occured
10061:
Finshed email agenda
Finished email agenda, no ftp items to do…
10061 is a Connection Refused error sent to you by the server. You could not make a connection because the target machine actively refused it. The most common cause is a misconfigured server, full server, or incorrect Port specified by the client.
Sometimes a 10061 error is caused by either a firewall or anti-virus software presence on the local computer or network connection. Either one may be blocking the ports needed to make a successful FTP connection to the server.
For a regular FTP session, please either disable the firewall or anti-virus software or configure it to allow CuteFTP to establish an FTP session over ports 20 and 21. Please consult the documentation or help file for your specific firewall or antivirus software product for further instructions. Usually the manufacturer of the device or software will also have specific instructions available on their Web site.
If you continue to receive the same error after insuring ports 20 and 21 are open, please contact the administrator of the site where you are trying to connect.[/b]
so if you are sure you have WD set up correctly - FTP port 21 - and that any firewall you have is not blocking connections then there must be a problem with anything weather!?
*******list of files uploaded********
C:\wdisplay\logfiles\\ca-marysville.txt
C:\wdisplay\webfiles\webcam.jpg actual messages from upload session* Start Time/date:11:57:59 1/11/2005
caz016.txt
Connected.
220-Microsoft FTP Service
220 Anything Weather FTP.
USER=****
331 Password required for ftpuser.
PASSWORD=****
230-Welcome to the AnythingWeather FTP site.
230 User ftpuser logged in.
TYPE I
200 Type set to I.
CWD weatherdisplay
250 CWD command successful.
PORT 192,168,1,104,10,84
200 PORT command successful.
STOR ca-marysville.txt
150 Opening BINARY mode data connection for ca-marysville.txt.
226 Transfer complete.
PORT 192,168,1,104,10,92
150 Opening BINARY mode data connection for ca-marysville-webcam.jpg.
QUIT
221
Disconnected.
