cloudy
Author Topic: xml data in Firefox  (Read 3806 times)
Offline 41South
  • Colin
  • Strathmore, Wellington, NZ
    • 41south.net.nz
xml data in Firefox
« on: December 07, 2004, 09:06:50 PM »
I've set up a test web page using the wdfulldata.xml data feed. It works fine in IE but not in Firefox. Any suggestions anyone? I wrote it using MS Frontpage - maybe that was my first mistake  :lol:
The page is here at www.larsenz.com/mambo/weather/weather2.html
Cheers, Colin.
Dallas 1-wire v3.0, Lightning, Humidity, Rain, Solar, Pressure, Temp sensors. Member of the Lightning Radar project.
bristolwx
  • Guest
Re: xml data in Firefox
« Reply #1 on: December 07, 2004, 09:25:13 PM »
I think the simple answer is that at the moment remote linking to XML data ONLY works in IE as it uses Microsoft data binding.
Mozilla have not found a way to do this yet I believe unless anyone can correct me.
Other sites using XML feeds this way state it will only work in IE.
Example
http://www.creativyst.com/Doc/Articles/XMLhtmlT/XMLhtmlT.htm
Offline 41South
  • Colin
    • 41south.net.nz
« Reply #2 on: December 07, 2004, 09:32:07 PM »
Dang. I knew it was all too easy. Thanks for the info. Back to the drawing board I guess.   #-o
Cheers, Colin.
Offline carterlake
  • Tom Chaplin
  • Carter Lake, Iowa USA
    • Carter Lake, Iowa Weather
« Reply #3 on: December 08, 2004, 12:00:33 AM »
Also, remote XML ONLY displays if ALL your visitors lower their security settings in IE.
Been there. Tried that.
WD; Davis VP2 6153; Quickcam for Notebooks Pro; Boltek w/ Nexstorm; GRLevel3; Live NOAA radio
Offline 41South
  • Colin
    • 41south.net.nz
« Reply #4 on: December 08, 2004, 12:37:10 AM »
So in theory then if I save my web page as a somethingorother.txt in WD and change all the xml tags to straight WD tags and get WD to upload that it should work   :roll: #-o 8)   ?
Cheers, Colin.
bristolwx
  • Guest
« Reply #5 on: December 08, 2004, 01:51:54 AM »
in other words, a custom page?
generated by custom tags in wxlocal.html so that WD uploads as wx.html with all the current data values filled in?
Yup that would work.
« Last Edit: December 08, 2004, 01:58:13 AM by bristolwx »
Offline 41South
  • Colin
    • 41south.net.nz
« Reply #6 on: December 08, 2004, 02:14:20 AM »
That sounds like what I meant to say  :lol: Thanks.
Cheers, Colin.
