What I am saying is that all I can see is the script that is scrolling down the terminal screen. You have to read it as it is scrolling. I would have thought there would have been a console screen that displays what is being reported. Something similar to the screen on my Weather Display windows software, that’s stationary.
It is not necessary to do that for me. I plan on using it headless anyway. I just thought it would be handy for auditing the data before sending it to Weather Underground etc.
One more question please. I have increased the size of my rain gauge from 4" to 8" to get it to report it in .01" increments. In doing this I had to put in an offset of .258. Can this be done in the configuration file and if so how do I do it.
Don’t worry about it right now. I’m not sure yet which way I’m will end up going. Is this the only version that will run on raspberry pi 3 or is there a more complete version that I can run.
I have managed to get a Gui version of consolewd created and uploaded now for the raspberry pi 3
just run where consolewd is and make sure consolewd is set to create a clientraw.txt file
unzip: http://www.weather-display.com/downloadfiles/wdpi.bz2
I guess I don’t know how to execute the wdpi file. If I can get this running I would like to get the rain amount setup. The only other question I have can this be set up to report to weather underground quicker than every five minutes.
you just run it
like
./wdpi
from where you have consolewd installed (i.e make sure you extract it to there)
or just double click on the execetuble icon
I am sorry but I’m at a total loss. If I run ‘/home/pi/consolewdfiles/ sudo ./consolewd’ I get the program to run in the terminal window.
If I look in the directory consolewefiles I see both consolewd and wdpi files.
If I run ‘/home/pi/consolewdfiles/sudo ./wdpi’ I get command not found
I also have no visible icon that i can double click on. If I double click on the file it brings it up in LibreOffice Writer.
I have been unable to get that file to work either. I am just not up enough on linux, yet anyway, to figure this out. I can’t get the file to execute as I do consolewd.
I think the program will be okay as it is, with the changes to the rain measurement. I can probably live with reporting to Weather Underground every five minutes.
I am working on getting the ftp settings correct so that I can report to the weather services. The settings on my Weather Display for windows don’t give me the settings that I need for the config file.
I am still working on it, hopefully will get it going today. I appreciate your help in trying to get this to work for me.
I am still unable to get the config file setup to send the data to the services. I am running weather display on a windows 7 machine, version 10.3753 and was wondering if you could extract the information needed from that software to complete the config file for the raspberry pi.
I will continue to work on this, but only by a process of elimination.
you already have wunderground uploads working, yes?
just make sure to exit consolewd when you make the changes
e.g set to Y for so cwop uploads
and set your CWOP ID and lat/long (what are you entering for that?)
Yes I have Weather Underground, CWOP and PWS working on my Windows version. Everthing on that software is working perfectly. Is the linux software for the raspberry pi 3 that is killing me. Its loading the data to my raspberry pi but I can’t get it to send.
