Windows Defender Security Center for AV, with CCleaner monitoring
I had been successfully using Ver 10.37S15 and decided to upgrade to the Build 60. Two issues popped up:
Despite choosing Davis WMII as my station type, the program indicates in the title bar that I am using Vantage Pro (the title bar used to show “Davis WMII”).
The temperature and Dew Point reading both show about a +25F offset.
While working with Brian’s on this, I reinstalled Build 60 and it’s working properly now. I’m including the following details in case it helps someone else.
At one point in the process, Brian asked me to generate the “C:\wdisplay\databackup\wdisplayftp.reg” file using the command from the menu bar: “Action → Back Up Window Registry Entries”. Before trying to reinstall Build 60, I double-clicked that file, which restores those entries. Also, I ran the registry clean-up tool from Piriform’s CCleaner software prior to generating the *.reg file. I don’t know if either of these actions caused it to start working properly, but it’s working now! Thank you, Brian.
