wxstatus issues (SOLVED)
Hey guys,
Put 2 custom checks in and the time stamps are not working. Can anyone help with this issue.
One file is updated every minute
the other file is updated every 5 minutes
on the status page it states the last time was 4**** hours ago
we are confused
thanks
You’ll need to post the code you inserted in wxstatus.php that causes the display
NWS-ALERTS NOT Current 419763:57:32 > 0:10:15
WEBCAM IMAGE NOT Current 419763:57:32 > 0:01:15
Sorry Ken,
$tDir = ‘./’;
if(file_exists($tDir.‘nws-alerts.php’)) {
do_check(langtransstr(“NWS-ALERTS”),$tDir.‘nws-alerts.php’,10*60+15,‘nws-alerts.php’);
$tDir = ‘./’;
if(file_exists($tDir.‘fixed1.jpg’)) {
do_check(langtransstr(“WEBCAM IMAGE”),$tDir.‘fixed1.jpg’,1*60+15,‘fixed1.jpg’);
The first one should be
$tDir = './cache/';
      if(file_exists($tDir.'nws-alerts.php')) {
           do_check(langtransstr("NWS-ALERTS"),$tDir.'nws-alertsMainData.php',10*60+15,'file');
and that will check one of the output files updated by nws-alerts.php script. You were checking the age of the nws-alerts.php script itself, not one of the files it produces.
The second one should be
$tDir = './';
      if(file_exists($tDir.'fixed1.jpg')) {
           do_check(langtransstr("WEBCAM IMAGE"),$tDir.'fixed1.jpg',1*60+15,'file');
Note that the third argument to do_check in both cases is ‘file’ (indicating that a filemtime check is to be done on a file in the filesystem)
Hey Ken,
put the new code into the wxstatus.php page and updated it. Got the webcam image to come up correctly but now the NWS-DATA did not come up.
http://www.southturnermaineweather.com/wxstatus.php
Matt
Sorry… that code should be
$tDir = './cache/';
      if(file_exists($tDir.'nws-alertsMainData.php')) {
I forgot to change both instances of the file to check.
Thanks Ken,
Works great now.
