I got my foscam ip camera working (ffmpeg h264) with the following url:
rtsp://username:password@here the whatsmyip adress.88/videoMain
Use this adress in VLC player…
rtsp://admin:[email protected]:88/videoMain
rtsp:// @192.168.1.11:88/videoMain
rtsp://:[email protected]:88/videoMain
rtsp://[email protected]:88/videoMain
Open the VLC, and go to MediaOpen Network Stream option, then enter the URL into VLC.
(From memory, the actual login specs are written on the camera…)
I did. Also changed the period before the port with a colon; figured it was a typo. Used my pc IP, starting with 159, not the camera IP. In Chrome it launched a search engine, in Firefox it generated a message that Firefox doesn’t know how to open this address because the protocol (rtsp) isn’t associated with any program. Maybe there is a browser setting I need to change.
SSDD. Maybe reboot the router? I’ve been hesitant because then I’m forced to redo the entire setup of the A/V receiver from scratch. But in my experience sometimes the ol’ off and on desperate measure actually works.
Also, not sure if it matters, but my PC is connected to the router wirelessly, not with a LAN cable. Works fine.
Maybe dismount the camera and bring it in and start from scratch there, as someone previously suggested, a factory reset? Also hesitant since it’s sending images to WeatherUnderground without problem every 15 minutes.
I’ve about run out of ideas so I appreciate the ones that keep coming.
Yes it works fine in the IP camera tool, which is the search tool, and the IPCam Client, but only in an old version of Firefox, not Chrome. Seems the plugins for the tool stopped working in newer Firefox.
It shows live video from the camera, screenshot attached here and in reply #18 of this thread also.
I believe I could, the attached screenshot shows both a factory reset button and a reboot button. Surely nothing could go wrong.
Before I did that I wish I could understand the result of the windows diagnostics showing the “online but isn’t responding to connection attempts” message. That message seems to imply that I have some sort of fundamental network problem, or my wirelessly-connected PC is the issue, and not the camera. Thoughts?
I have read through this thread again and downloaded the manual
the ip address 192.168.0.9 in the session status is the ip of the computer accessing the camera not the camera ip
you client software is using 192.168.0.3 and is giving you a picture, I assume you have made that a fixed ip in the camera, and that port forwarding is enabled for port 88 in your router.
I would try 192.168.0.3:88 instead of 192.168.0.9:88
