Hi Brian. After updating to WD v 60 on 11/15/17, CRONPWS is not working via the schedule inside Weather Display…I can manually execute cronpws.exe and it successfully sends it but the WD PWS module is not running at all at my upload schedule of every 15 min…BELOW IS A LOG ENTRY OF ONE OF THE MANUAL SENDS…my password is just alpha-numeric…nothing special
Now that you say that, right before updating to wd b 60, windows 10 did download and install an update here on my end, too…I had forgotten that…so thanks again…
HI Brian,cronpws.exe being flaky again…no data sent for 24 hours…was working like clockwork…blast…wdb60…error log empty…clicking “TEST A DATA SEND” does not execute…executing the cronpws.exe in the WD root directory does send…
are you sure you are still using the new update of WD?
try downloading again
the change I made was that the executable path to the .exe file was not a full path…it is now
No luck, Brian…neither zip or full version worked…again, when I click the test data send…nothing happens…too weird…any other thoughts?..all other modules working well…
