Does anyone know if Weather Display will work with the Ambient Weather WS2902 in the title?
https://www.amazon.com/Ambient-Weather-WS-2902-Professional-Monitoring/dp/B01N5TEHLI/ref=pd_ybh_a_3?_encoding=UTF8&psc=1&refRID=Z8FNS48QQ7064S21KHCC
not sure
WD can work with the WiFI type station, but this one is a different model
WD will work though indirectly by using the wunderground data feed (see in the stationless weather station type setup)
Probably you could find useful this post:
http://discourse.weather-watch.com/t/62008
Probably your station works as other WiFi models. In my case, my station hasn’t console, so I only can access to “bridge IP” device. But if the station can send data to WU, probably works some of the solutions on this thread. If you can change the destination URL where the WU packets are sent, you can sure use my method:
http://kona2.alc.upv.es/Estacio_Meteorologica/aercusWDsetup.htm
Ruben
great write up that
Can I make that a sticky thread?
