Are you saying your server is rejecting the url script or does it require an header to utf8 on your server or an str-replace to strip Norwegian characters . Looks server related by your description.
Gonna have to go through the process of elimination by the looks of things and if it
Solved this issue. For some reason the rewrite rule wont kick in when the data is sent from WD, had to add www in the URL’s in WD. Works OK from browser… Anyway, seems to be OK now
awesome another tip to note … we learn something new everyday…have fun brian, dont forget check the api key and write permissions for the jsondata folder…
