Hi using the latest version of weather display with meteobridge the wind graph on main page is blank any ideas how to fix
Richard
Richard
Sorry meant wind direction
which version/build?
Brian the build number was posted on 31-10-2017 up to that point i was using 10.37S Build 57 this is running with no problems.
Build from 31-10-2017 gives the following problems
sunrise/sunset will not update
day/night will not update shows sunny day all the time
no wind direct showing on the graph
after about 10 minuets program locks up no data received
please note i have only used these two builds am currently using 10.37s build 57 which runs fine
operating system is windows 10 pro/Meteobridge 3.4 (Oct 26 2017, build 11579), FW 1.4
Richard
there are many posts every day from many people
its impossible for me to know and remember what every persons situation is
so that it why its important to provide as much information as possible
(e.g like was there any error under view, program event log, etc)
I have been working on adding history data from your wunderground data for use with meteobridge for when WD was not running
you would need to be at least using the latest update as I have made a number of fixes to that
