I can not get twitter to send text lately. I can get it to send if I manually run edtwitternew.exe
What I had to do to get this to work on a schedule is use widows scheduler to run wdtwitternew.exe
you might instead have just had to set it to run at a different time in WD to other times (e.g using the minute offset)
I never thought of that. I will try it
nope, it didn’t work
is there any error in WD under view, program event log?
Nothing, log is empty
when you set the minute offset did you then reset the times to send?
yes, every 30 minutes with an offset of 2 minutes. I tried offsets up to 6 minutes
if you could .zip and email me your settings files, I will test here
you do not say which version/build of WD you are using
10.37S b59
I will zip and send
is this a new problem, or?
(the more information you can provide the better)
I Have tested here with your settings and WD works OK
I notice you still had set to go on the 30 minute past
and no minute offset applied
also try
click on reset settings
then click on test/re authorise
then the authorise window should show up
and then the tweet should get sent once you OK that
then try setting a minute to tweet 1 minute ahead and see if that works
reset did not work,
However it did post when I pressed test.
It just won’t post on its own
it does here
with your settings
e,g for any time I set
e.g like in 1 minute ahead
note that using the test in the twitter setup does not run
wdtwitternew.exe
that should be run instead at the set time
check to make sure that file is not being blocked by your firewall or antivirus program or similar
I set it back to 0 to use windows scheduler
It is a new problem. It was running fine for a long time. It showed up about 2 weeks ago
I am using build 59 and my tweets are going out at the times set in WD OK
I quite often have the same problem with my twitter feeds. Mine stopped sending about a week ago which I missed. Removing the weather display app from my twitter account and resetting up worked once. Thereafter no automatic tweets, presing the test/authenticate button did not work even though last data sent indicated it had. In this instance I reinstalled the last version which was 10.37S59 twitter feeds worked straight away. Looking back my feeds stopped after installing 10.37S60 .
