it does not really matter
just change the number, and see what the result it
if its not enough, then increase or decrease that number
I could make it in the main screen customisation where you could adjust the size of the dials via a spin selecter
Thanks Brian I like the new dial. I just want to change the color of the number so I can read them and I don’t seem to be will to do that as you saw from screenshot
From my prior post the colors change when I click on the Dial and get the pop up but when I’m in WD itself there still the color I can’t read look at the screenshots I think that will make more sense
you are refering to the weather dials screen (e.g from view, weather dials)
i.e so you have changed the colour for the weather dials
you should be able to change the colour of the main screen gauges and not the weather dials gauges
from the colour setup
Hey Brian thanks for really appreciate everything you and your patience
I must be doing something wrong
Checkout screen shot you can see where change the dials to Aqua blue. Below that is when I’m in BWD main screen and I clicked on the window dial and you can see it’s aqua blue.
Yet when I close that pop-up window and go back to the main wd window the colors go back to the old colors
One more interesting thing is when I go back into the set up screen the colors go back to the original new more are blue
Hence why think I’m obviously doing something wrong for something so simple
When I change the colors I’m hitting okay and then okay again is there anything else
I cant see any reason why it would not work
only issue might be with the silican labs USB driver
the version of OSX after this latest is a different story though, its 64 bit, and its not clear if 32 bit apps will run at all
I need to wait for the compiler to be updated to 64 bit for OSX
the new linux version is 64 it though and that is very similar to the Mac version
I have tried it on High Sierra and for my weather station (3081) and it doesn’t work. It will work fine with live data but if you shut WD down then start it again thats where the problems begin. It crashes all the time and you can’t get the historical data from the data logger
