Weather underground stopping
I am running Ver 10.375 build 59 just upgrade from build 57 upload to weather underground stops if you hit test it will start and then a few mins if stops.
the data is sent via the cronwdwu.exe
but that program is the same version as in build 57
if you are using the rapid fire, that is done via the WUrapidfire.exe program
and that is the same version as used in build 57
is that program running?
what shows in that program?
is WD getting live data from your weather station?
check to make sure that your firewall or antivirus program is not blocking the above programs or similar
I was running it on rapid fire and it had worked up to a couple of days ago I have since shut it off and the last time I checked it was uploading to weather underground.
the wdrapidfire.exe program has not been changed for some time
Not sure what is going on with the rapid fire it has now started to work again.
wunderground has not been very reliable for a while now, with things stopping working and then starting working again ,etc
