Offset for solar
Hi, I have a wh3081 with solar that sends very high values. I’m using your offset in order to calibrate UV, but Solar offset is not available.
I’m kindly asking for the release of this feature
you can do that already
try either
in the solar setup, thresholds, adjust factor for solar from uv and also the calibration factor used to get solar from the uv (default is 0.0079)
or in the offsets setup, solar , adjust for solar (% adjust)
You are right, Many thanks and sorry
Giordolo
