Hi. I am running the very latest WD version (Build 58) with Windows 10. I had been running a dual monitor setup with the WD displayed on the second monitor. My 2nd monitor failed and I am now running WD on the primary monitor. Brian helped me reposition the main screen startup by going into the wdisplay.ini settings. I am now trying to access the Control Panel but when I click on it it doesn’t display. I need to find out how to get the Control Panel to display on my one primary monitor. As always thanks for any help.
The control panel position will also be in the wdisplay.ini file. So with WD shut down, search for [control panel] in the file and try setting left and top values to zero, save and restart WD then open control panel to see if it appears.
OK. Thanks much.
