i have just installed weather display software and have been trying to upload data to weatherbug and pws and neither works, weather display reads data from acurite pro 5 but it stops there. I have searched message boards and cant’ find any answers. I have internet main switch turned on in weather display and dont see any issues with either setup screen for weatherbug or pws.
for PWS
what shows in the
sentpwsdata.txt
file
for weather bug, it uses the Ftpupd.exe program
what shows in the ftplogfull.txt file?
make sure both of those .exe programs are not blocked by your firewall or antivirus or similar
http://www.pwsweather.com/pwsupdate/pwsupdate.php?ID=1A3COP&PASSWORD=x#SL6T7af0eu&dateutc=2017-10-17+03%3A49%3A00&winddir=035&windspeedmph=0.0&windgustmph=0.0&humidity=95&tempf=43.3&rainin=0.00&dailyrainin=0.360&monthlyrainin=0.010&yearlyrainin=0.010&baromin=28.393&dewptf=42.0&weather=RA&clouds=CLR&solarradiation=&UV=&softwaretype=WeatherDisplay%3A10.37S&action=updateraw
OK
It don’t seem to be reading data and i don’t know why.
list of files uploaded*
Start Time/date:11:50:05 PM 10/16/2017
Permanent connection selected
Checking for what else to do…
there are 1 more things to do
weather bug connected status: OK
OK
weather bug complete
Finshed email agenda
Finished email agenda, no ftp items to do…
if you put
into a browser URL
it returns
not a valid weather station ID/password
If i go to pws setup page in Weather Display it has correct station ID and password and i can click on “view your data” link and it takes me to a pws page with no data filled in.
https://www.pwsweather.com/obs/1A3COP.html
I also tried to modify password on setup page and then clicked view your data and i got an error.
the message returned is that either the user ID or password is not correct
that is why the data is not getting to PWS
you can try it your self
i don’t know what else to do, i put password in 3 times and twice was copy paste and once i typed it in and no change.
try changing the password to one with out any special characters
From the PWS FAQ:
“Passwords can have ONLY letters and numbers, no punctuation or special characters are allowed. If it does please click on ‘Profile’ in the top menu bar and change it to one that only has letters and numbers.”
well my mistake there on password, you are right i had special characters in it so i got that changed and it works now on PWS !! Thanks so much !! Now i am having trouble on weatherbug and i had same password in there so went and changed that and i get error when i click "view your data " don’t know for sure if its my end or the website at the moment.
Update: yes it was weatherbug website as it is working now. Thanks so much guys for your help with this !! All good for now.
I am using build 60 and the updates are OK here
do you have any error under view, program event log?
