Would love to be able to recreate high soil temp in lg2.txt if the option isn’t already there please?
Regards
Guru
Regards
Guru
how do you mean recreate it?
you can edit that logfile and WD will then change its data after re reading in the data from that logfile, if that is what you mean
I realised I had log snow depth instead of high soil temp and wanted to go back and fix the data in those logfiles.
Regards
Guru
you can change that setting and then edit the logfile and then WD should reflect that
