Detailed Rain Chart (micro bug)
This is a very small bug that has been around for some time.
On the detailed rain chart
(View Panel → Rain Chart → Detailed Rain Data)
“Wettest Year Total” - Total has an extra T, shows “Ttotal”
Also any adjustments to the fields or box will not stick after a restart as the left side text in the lower part of the chart is always cut off some.
After using the procedure to allow resize and then save under advanced/Misc Settings → main window customize it will not save the changes as it will with other boxes/windows and main screen in WD.
Current version running is 10.37S B57 on a windows 10 system
Ok, next update will fix that typo
re the changing the window size and saving that, I had not allowed that
could you post a screen shot of what text you are seeing cut off?
Brian,
Thank you for the follow up on this.
I can resize it and it will stay as long as the program or computer is not restarted.
Attached is what it looks like after a restart.
On my precip page is how it looks once the boxes have been resized.
