Weather Display Generated Webpage- Zone Forecast update issue
OS - Win 10pro
WD - Version 10.37S57 (Version on 27 September 2017)
Brian,
I’ve noticed for a while now Zone forecast is not updating on my Weather Display Generated webpage. Please assist. Thank you.
  1. I have to go into FTP/Internet setup, NOAA Forecast Download, then select test to update.
  2. I can manually update to the webpage by going into the HTML Table/Carterlake web page and create the file and then upload.
Update is every 10 minutes. Check the box to include text files on my webpage.
http://curtiszmweather.com/wxwdzumbrota.php
Example:
Weather report/warning/Metars
Expires:201710022115;;241782
FPUS53 KMPX 020835
ZFPMPX
Zone Forecasts
National Weather Service Twin Cities/Chanhassen MN
335 AM CDT Mon Oct 2 2017
MNZ078-022115-
Goodhue-
Including the city of Red Wing
.TODAY…Showers likely with a chance of thunderstorms in the
morning, then a chance of showers and thunderstorms in the
afternoon. Highs in the mid 70s. South winds 10 to 15 mph. Chance
of rain 70 percent.
normally you would have that setup via the 5 day forecast in WD and have that being updated and use a custom tag for the day (1 to 5) that you want
but the way you are doing it is a different way
I guess you need to make sure that there are times set to download the file needed and then you need WD to upload that file to your web page
yes?
Brian,
The only way zone forecast updates for the link below is through File#1 in Customize Internet and File Creation Setup. It is added to the Zumbrota Weather.php file.
CurtisZM Weather - Weather Display Webpage
Brian,
The Zone forecast is created in the web page generation
