Hi Brian. Was wondering if there’s a way to force the clientrawdaily to update?
A script im running uses that file and as you can see here, all of the data is the same… https://www.northbendweather.com/valleyrecord.php
it does get updated by WD 3 times a day
you could try restarting the clientrawrealtimeftp, it should then do a new upload on first upload
I restarted the real-time, and it didn’t do anything.
Maybe a setting somewhere i inadvertently messed with to cause this?
It seems the data is changing, but it’s affecting every day and its not sticking. The highs and lows are always matching.
Hi, it might be due to that power glitch you posted about and seemed to corrupt this month’s datafile. I suggested you convert the logfile to datafile and recreate last 31 days data. Did you do that by any chance?
I did convert the files and it fixed everything but this issue.
Im wondering if deleting that file and letting it recreate itself if that would do anything.
Client parser info… https://www.tnetweather.com/wdparserold/index.php?site=Https%3A%2F%2Fwww.northbendweather.com&submit=Submit#Clientrawdaily.txt
Rebooted wd and now its fine. #-o
