Wunderground webcam upload "every minute" apparently not working
Hello,
I’ve recently setup a webcam to upload to Wunderground, I wanted it to be uploaded every minute so I checked the “Every Minute” checkbox but apparently it doesn’t work.
The only thing that affects the uploads are the times listed (if you leave empty, it never uploads even if you checked “every minute”).
For now I have configured it to upload every 5 minutes and it works, regardles 1minute feature checked or not.
Is it possible to check the feature?
General Infos:
WD ver 10.37S56
Windows 10
Thank you
I have tested this and it does work and others do have this working
note that wunderground had problems recently
so maybe try ticking that option again
I tried again and this time it worked…I guess that when I first tried wunderground was not working.
I see that very often there are entire hours in which wu webcam upload does not work…for example now as I am writing #-o
Thank you for your kind support :thumbright:
you can set WU to pull your web cam image from a URL
