Install Error
While upgrading from 10.37S.55 to 10.37S.57 I get the following (see screen shot) …I abort the install and when I run WD the new version is installed and WD works normally.
This also happened on the last upgrade…
As far as I know, the program is working normally.
Thanks…
that error occurs if WD or an associated program is still running
Hmmm, I did try to install it while the current version was still running…I don’t remember about the last time it happened…
What ‘associated’ program/s would cause that to happen if I had closed WD and it happened?
Thanks for the quick reply…
always make sure to exit WD first
that particular dll file is used by the weather voice/answerpone functions in WD
Thanks…
skipping that file will not effect anything as that particular dll file has not changed/updated anyway
I figured that much when the program ran right in spite of the error msg…
