Using a Belfre logger. I was able to extract data but some bad news. It appears there was some water egress and the ISS stopped reporting. It started again about 20 hours later but now the anemometer and wind direction is no longer reporting correctly. Only getting 1-5mph readings since it came back online. What I did see is that was a we had a 70mph gust before it stopped reporting.
I’m often tempted to re-build my ISS electronics unit in a NEMA waterproof box. I just don’t trust that seal design to stand up to a real storm - fortunately we never get those
I have a correction. Just looked at WU and I see the figures are a bit different than what I seen in my WD logs, but I might have missed that since I was pretty whipped from all the travel when I looked at them. WU shows an 84 MPH wind gust at 6:14 when the anemometer stopped reporting and and 28.11 barometer at 7:00pm. Rain was 5.11" but I’m sure sure that isn’t correct. With the wind speed and the shaking of the pole mount in those winds it could be just about anything. Didn’t start saving data again until 8am the next morning.
I’ll have to take a closer look at the log files when I get a chance.
We got power back this morning, after 3.5 days. We do have a Generator and were able to keep fridge and freezer running most of the time and only had minimal spoilage.
No damage to anyone right around us but just a block or two away in both directions trees into houses and cars occurred
Those close to rivers and streams are still suffering from Flooding as well as trees down…
But everyone we know came through basically fine with little to no real damage and no injuries so that is what is important
@hankster
that is a decent gust! @JaxWeather
great you are OK and you had a back up generator
I would have thought more in Florida would be offgrid?
also I am surprised not more power is underground (which is not full proof either though but must be better) and or not more maintenance is done on trees near power lines etc?
At peak more that 6 million were without power. A lot is underground but the damage covered basically the whole state (400 miles x 150 miles) and I would guess a lot could have been a cascading effect.
Based on the numbers I can find Florida actually has a surprisingly low number of home solar installs compared to the population. I’m not sure of the reason for that but maybe utility power is cheap. In general there are very few off-grid solar installs here except in very rural areas where no grid power is available. The common grid connected solar systems (like mine) are designed to only generate power when the grid is up.
Just to add, much of Florida is sand and is difficult to dig without collapsing. This allows it to drain well but it is unstable. Second is how low the land is. I am about 10 miles from the Gulf and I am only 9 ft. above sea level. There is a lot of moisture in the soil and much of the area is prone to localized flooding even in heavy rainstorms.
Much of the city (and many other cities in Florida) are criss crosesed with canals which makes underground much more difficult and expensive to install. See attached map of just one part of the city.
That’s a reliability issue, and here in the west it’s a fire issue too. PG&E, the near monopoly electric utility in N California, has paid big penalties over the years for fires caused by trees contacting power lines. They’ve been spending more money and doing a better prevention job recently. In my local area a contracted vegetation management company is continually monitoring the lines down to street level. They have all the trees and their species mapped, and the software predicts growth.
That is a problem but I guess the ease of repair makes up for the problems underground have. As of this morning, our county of 260K residents, 29% are still without power.
On the question of off-grid I did some research. Local electric in my area is 10.4 cents per kwH (converts to 15 cents NZD). Looks like that is about half of NZ prices.
Must be a lot of “fees” added on if it’s only $0.0015NZD/kWh ( $0.0011USD/kWh) for the bill to average $40NZD ($29USD) a week. My summer weekly bill is about $20USD with winter weekly bills about $10USD.
Yes, summer bills are a lot higher than winter. Lots of AC in the summer and seldom any heat needed in the winter.
